Question about Canon imageCLASS MF5750 All-In-One Laser Printer
My printer says check paper size it has on screen cassette a4 how do get it to legal size
Open the paper tray and extend it to legal, then place legal paper on the thing. It is the only way to solve this problem
Posted on Aug 19, 2010
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Konica minolta how to copy legal paper in a4 size
use your zoom feature most copiers don't have a conversion metric a4 to inch (US)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 02, 2014 | Konica Minolta bizhub 180 All-In-One...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
468 people viewed this question
old marine
old marine
