Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Compressor not running - Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezercompressor not running - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Tcompressor not running - 2_bing.gifting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Air ride compressor not coming on 1988 lincoln mark vii
It could be your compressor. You can check this by popping it out and putting a 12 volt source on it.
Aug 30, 2014 | Cars & Trucks
Why is GE Profile Bottom Freezer Refrigerator not cooling
Check manual for proper setting.
Check compressor running condition. (set to lowest temperature and let the doors open. the compressor must run contineously. Feel if it is cooling up. If so then close the doors and observe the compressor running behavior. It should run for minutes before the compressor stops.
If compressor is running but no cooling effect it is either leakage of freon or loose compression. let it be checked by a certified technician.
If compressor is not running at normal temperature check your thermostat and OLP (over load protection) relay. Both must be closed circuit.
Aug 13, 2014 | GE Refrigerators
1996 amana top freezer refrigerator not cooling
Check power to and from thermostat and to compressor relay. If compressor powered but not running, compressor fault. If compressor running but no heat in condenser, short of gas. If compressor running and heat only in first rungs of condenser, compressor poor pumper and needs replacing.
Apr 28, 2014 | Refrigerators
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
My cooler compressor start stops imidetly..why
There is a start / run / thermal overload relay on the 3 compressor input terminals that has 3 functions
1. enage the start winding
2. switch to run winding
3. Protect the winding in the event of a bad start or locked compressor rotor.
If it is actually starting but not running at full speed / normal RPM the run capacitor can also be bad.
Unless the compressor is locked up... the cost to repair the unit is worth the expense. The only thing that would be bad news is if the repair person told you the compressor rotor is locked and the compressor needs replaced.
From the symptoms you described you have a compressor run component failure and the the compressor rotor is not locked.
Feb 02, 2010 | Franklin Industries FBC360D Beverage...
Compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Oct 14, 2009 | Ingersoll Rand Air Tools & Compressors
Lennox Diplomat 10AC48-1P, outdoor fan runs compressor will not kick on. Replaced contactor, still no compressor. Could there be an issue with dual capacitor or start capacitor that would prohibit the...
There could be the compressor capacitor is damaged.Sometimes on the duel capacitiors they will still run the motor,but doesnt have enough power to turn on the compressor.Or the compressor could be bad.
Aug 18, 2009 | Heating & Cooling
Side by side not cold
compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
drcool
Sep 09, 2008 | Kenmore Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
