Question about Sony KP-57HW40 57" Rear Projection Television
Guns won't stay aligned. Looks like a bad 3D movie
  • Sony Master
  • 8,457 Answers
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board,must require to change 2 STK convergence ICS and some or all it resistors to solved the convergence problems.U have soldering tools and matrials and know basic's solderings work?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair it ur self.The shop will cost $300-350 for parts and labors.
Posted on Jul 10, 2010
My picture looks like it is in 3d there shadows on people
Older projection TVs use three separate "light guns" to essentially paint the picture on the screen. What likely happened, is one of your guns went slightly out of alignment.
You can either get it repaired, or attempt to align it yourself. It is doable, though tricky and rather risky. The process would depend on the type of TV you have. If it is a TV that uses the three separate light guns, then it's likely a few years old, and it might be tough to find instructions online for your particular model.
May 10, 2011 | RCA Televison & Video
When the tv is first turned on the picture is great. After about 5-10 minutes the picture looks like a 3 D movie when you're not wearing the proper glasses. Sometimes turning it off for 10 minutes and...
the 3d effect is caused by a mis alignment of the tree tubes you probably have a broken FRAME holding the tubes in place so that HEAT or VIBRATION can move them and the alingment is off dont forget you have one tube for RED one for GREEN and the other for BLUE if they are not aligned properly they can look like a 3d pcture without 3d glasses ha! sorry for the bad grammer...
Jan 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
The picture looks bent and looks 3d...my friend who sold me the tv had the same problem and she was able to fix it but she cant figure out how to do it now ... somthing about the red and blue being off...
In the tv menu settings there should be a convergence menu or alignment menu...you need to go here to re-align the red and the blue guns to display the proper picture...most projection tv's have a setup screen for aligning the colors..you want to line up the red and the blue to get as close to white as you can
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
Can Not Align RED via single or multip point conversion
The phillips DPTV305 - DPTV345 convergence repair kit is the right kit for your model which should solve that issue. The kit is available from www.tvrepairworld.com and also contains the CD with instructions.
May 13, 2010 | Philips Magnavox 51MP392H Rear Projection...
Convergence box is out - the picture is like looking at a 3D movie without the glasses.
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | RCA R52WH73 Projection Television
Need to activate dvdxcopy gold
this software in my own experience is not very user friendly. I recommend getting on a torrent site and trying different DVD software instead actually. Unless you purchased a key, then click on help, and there you should be able to enter your key code to activate in the 'About' section or Register.
Oct 20, 2009 | 321studios DVD X Copy Gold (200095) for PC
I have a 1999 p46811LV rca. When i turn it on it looks like i'm watching everything in 3D. The menu screen also has a bad bow to it. What is going on and how do i fit it? thanks Frustrated in 3D
There is an alignment problem between the three color guns. You CANNOT fix this yourself. There are DANGEROUS high voltages inside a projection TV, especially around the CRT where the steering magnets are located. This voltages can persist for WEEKS after the set has been turned off. Take it to a qualified television repair service.
Oct 10, 2009 | RCA Televison & Video
My rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Jul 14, 2009 | Televison & Video
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Sony KP-57HW40 57" Rear Projection Television Logo
123 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
