The frigedaire washing machine will not start. Panel indicates "loc" and door locked light does not come on. Model gltf294ofs1
SOURCE: Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Posted on Oct 15, 2007
SOURCE: LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Posted on Dec 30, 2007
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have error code loc the machine won't
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
What does LOC mean, that's what the screen displays along with err, when I try to press start or cancel.
Aug 17, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
Jul 02, 2009 | Kenmore Washing Machines
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Kenmore 417.44092500 front load window shows Err then flashes LOC and the minutes for the particular load setting. Door doesn't lock. Tried to get into diag code setting on spin/drain and pushing pause &...
Mar 08, 2009 | Washing Machines
I have a frigidaire front load washing machine
Sounds like it needs replacing from what you have said. You could try to free up the locking mechanism by going behind the lock on the washer from the top and the door catch. If this fails to solve the problem, then you will need to buy a new unit. You will get one online from Seme Nedis Ltd. You will should find the washer model number on the outer edge of the door. I hope this has been of some help to you.
Nov 29, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
