Question about Nikon COOLPIX L4 Digital Camera
Camera Lens up, not turning on
My nikon won't turn on, and the lens is stuck and won't go back down. The batteries are fully charged, and I even tried connecting it to my computer and turning it on. Nothing worked, can anyone help me?
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Lens won't come back
If the battery is discharged then it is likely the lens is stuck . If you can get the battery to charge and then turn on the camera it should help the lens come back. The camera will not turn on when the battery charger is connected. So you will have to wait until the battery is charged and turn on the camera only after disconnecting the charger.
Apr 28, 2014 | Nikon 26302 Coolpix S6300
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Cameras
Say error and lens will not go back in and shut down
Try to remove the battery and after 10 minutes install battery again.
Charge the battery to insure a fully charged battery.
If it does not reset, push lightly on the lens and try to have it go back in.
It could just be stuck. If this does not work, you have a major failure. It is cheaper to purchase a new one. Good Luck
Jan 07, 2011 | Nikon Coolpix S210 Digital Camera
This Tamron used with my Canon 1000D gives since 3 months errorcode 01 (communicationfailure between lens and body). When "off" and "on" can take one picture, then errorcode 01...
Jan 05, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Never used it. Turn on the camera and it says
1. Ensure batteries are fully charged.
After all this if its not work then the lens guide pin is damaged & replacing the lens is the solution of your problem.
May 19, 2010 | Nikon Coolpix 4600 Digital Camera
Lens stuck
If the battery is fully charged, and you are able to turn on the camera but only the lens wont come out, then try doing this:
1. Hold the camera from your right hand with the lens facing down.
2. Hit the base of the camera to your left palm as you press the ON button to turn on the camera. Do this a couple of times until the lens comes out.
Chances are, your camera's lens is stuck inside because of some granule of sand or dirt stuck on the sides of the lens inside. Goodluck!
Oct 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
May 22, 2007 | Nikon COOLPIX S5 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
