Question about Maytag M7Y15F2A Air Conditioner
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
  • 6,826 Answers
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Posted on Jul 10, 2010
Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
What causes a unit will turn on for about 1sec and then shuts down with the letters EEon display
EE is an ERROR code typically it is a disconnect from the control and the unit, this is inclusive I believe so the thermistor or sensor is bad or off at the board.
Jun 06, 2014 | Fedders A6Q10F2B Q Chassis Room Air...
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
The Maytag a/c unit model #M6Q10F2A has been working fine until this morning. The display reads "EE" and the a/c does not work. Unplugging the unit does not help.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Maytag M6Q10F2A Air Conditioner
Letters EE came up in display, and it cut off! now, not cooling
The problem is in the electronic control. I have reconfigured these in the past using older style controls and had some success.
Jun 12, 2009 | Heating & Cooling
Shutting off
I would try the same solution as the E1 error code, Not sure if it will work, but it seems to be the same issue
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Sep 10, 2008 | Sharp AF-S120FX Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
May 28, 2007 | Comfort-Aire RADS-151 Air Conditioner
Maytag M7Y15F2A Air Conditioner Logo
405 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
