Question about Samsung DLP HL-P5663W 56" TV
The power swith will turn it on and off by itself. Won't stop
After plug in, the TV will turns it on for 5 sec, then it goes off as a cycle.
Never stop. I have to unplug it from power. I tried unplug for 5 mins, then replug. It won't solve the problem.
    Sergeant:
  • 171 Answers
Hey there from what you have told us so far I think that you are having problems with your Light Engine System.
your light engine is composed by four different parts
projection lamp,ballast board,color wheel and DMD board
when some thing is wrong with your light engine you will get blinking flashing light infront of your tv set like you are right now
the lamps avarage life span is around 6000-8000 life hours for the original one witch can equal around 2-4 years if lucky a little more
so if you have not replaced the lamp before it would be the first place to start 80% of the time for DLP projection that is the problem
here is a link that will show you exactlly how DLP projection works
hope this helps
http://www.howstuffworks.com/dlp2.htm
Please rate this solution !!!!
Posted on Jul 15, 2010
  • Samsung Master
  • 8,457 Answers
This tv have a colors wheel.U hear grinding noises? Picture flickers black&white.That the indication the colors wheel is dead,need a new colors.U have Lamp LED front Lit up or flashes?That mean the projection lamp life is over,require a new projection lamp.U hear alots of clicking sound?That mean the Ballast board is dead,this board help to ignite the projection lamp.
Posted on Jul 10, 2010
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
I have a 47 in projection tv for almost 10 years it just stopped working. If I plug it out and plug it back in it turns on for about 5 seconds and then turns off by itself. I have to plug it out for it to...
The most common power is the main power board that goes bad on that set, and it is going to run around 500 on repairs. If it is a processor problem, then you need to leave it unplugged for 40MIN. and it will rest to normal, but if it don't you are looking at a repair job.
Jan 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Philips lcd tv swithes itself of 37pf9731d/10
I fixed this by replacing the off/on switch which seems to bypass the stand by transformer which i think was causing the problem hoppe this helps someone
Dec 28, 2008 | Philips 37PF9731D 37 in. HD-Ready LCD...
Samsung DLP HL-P5663W 56" TV Logo
322 people viewed this question
Jerry Greenberg
Jerry Greenberg
