It does not look like a camera problem at all coz the other flash is working well with the same settings. However if you can get me the make and model of the cam, I can tell you if some adjustments can be to correct this problem.
i am using a nikon d200- i have a few and swap cameras and flashes for various jobs. You think it is a flash problem then?? Really it must be since the other works perfectly fine. i am wondering if i should send to nikon for repair. i dont want to "put a bandaid" on it correcting with camera settings as much as i just want the flash to work as it should. Thanks.
In that case then yes, I do think you should get a new xenon lamp for the flash or a new condenser(holds the charge for the flash to come on) for it. I believe that condenser is not charging as it should and that it is the source of the problem. A local camera tech should do the job for you at a reasonable cost.
thanks- I will send it back to a nikon tech
