Question about Linksys Wireless-G WRT54G Router
I have a cable modem but i'm having problems with setting up the linksys wireles network
  • Linksys Master
  • 2,263 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Jul 11, 2010
    President:
  • 1,851 Answers
Hi
You say you are having 'problems' but this can mean from getting into the unit to matching it up to causing it to overload to many things. SO - I want you to put up here - what you mean EXACTLY as you can.
If you're looking just to open the unit and change settings - leave the username blank and put in 'admin' as the password. This will get you cranking.
If I can help more - be specific and don't be shy about using our premium support as this get's you to the top of the list in a hurry.
Thanks
Gary Rice @ Fix Ya
RICESKI
Posted on Jul 10, 2010
Do i a modem to use with my Linksys Wireless WRT54GS
You dont require a modem as there is a built in modem in linksys router.
May 28, 2012 | Linksys WRT54GS Wireless Broadband Router...
How can i install a linksys router without cd?
With a Linksys router, you simple connect the power cord to the router (with nothing else attached to it), wait for it to boot up, which normally takes about 20 seconds, and then you take a paper-clip or pen and press the RESET button in firmly for about 30 seconds, then let go. This will put the router into factory-default mode.
Then, you wait about 30 seconds for the router to boot up again, and then plug the internet cable (from the DSL modem or cable modem) into the WAN port. After that, connect your computer/laptop to one of the LAN ethernet port. Your computer should pick up an IP address of 192.168.1.2 (you don't have to verify this. You should now be able to access the internet.
If you want to change settings on the Linksys router like SSID, wireless security, IP address, DHCP, etc... you just need to open up Internet Explorer and type "192.168.1.1" into the address bar. It'll prompt you for a username and password. Depending on the model and age of your Linksys router, it might be Admin/admin, <blank>/admin, admin/linksys, or admin/password.
Feb 27, 2010 | Linksys WRT54GS Wireless Broadband Router...
I have a linksys Wireles-G broadband router 2.4 GHz that i am trying to hook up to a desktop to allow wireless access for a laptop and I cannot get it to log onto the internet. Why?
Then you need to connect the computer to the router and the modem to the router.
Feb 21, 2010 | Linksys Wireless-G Broadband Router
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
Linksys wireless print server WPS54G - wireles network problem
access your router and go to wi fi settings check is it enabled if not enabled it.
Also check its netwrok settings like dhcp , ip addreses , subnet mask gateway.
Also check in your network that in gateway is always your linksys ip.
Let me know .
Jul 29, 2009 | Linksys Wireless-G WPS54G Print Server
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
WRT54gs' internet link wont come up
Here's a couple of places to get started:-
1. If you're on the internal network, try logging into the router's admin page, and iff you can see link to the cable modem / DSL line "Internet Interface". Try Refreshing DHCP on that interface.
If it's not looking great, or it's not serving out DHCP, do a quick powercycle on the LinkSys and see if that clears it (I would guest you've tried this though!)
2. Check your cable modem / DSL line box and ensure that all its lights are as normal (Without Make / Model etc I can't help you in detail there.
3. Try powering off your cable modem / DSL box and then your link sys. Wait 10 minutes (Yes, that long, there are reasons for that involving the upstream network). Powerup you Cable Modem / Link Sys box, once that looks healthy (Maybe 2 minutes to boot with some models) power up your LinkSys and see how things look then.
If you're still not having luck, unplug the power from the LinkSys again. Press and hold the "Reset" button, keep it pressed, and reapply power. Count to 10 before letting go. Wait a second or two, then press and hold the rest button again for another 10 secs. See how it looks then.
4. If all of the above doesn't help, call up your ISP and ask them to run a diagnostic on your Cable Modem / DSL Modem.
5. If you CAN get to the web page on your LinkSys, and you KNOW the cables are good then you should try putting the original firmware back and see how things go then.
If you're still having issues after all of the above I'd suspect you have faulty hardware.
Nov 16, 2007 | Linksys WRT54GS Wireless Broadband Router...
CANT CONNECT
you have not given enough information to solve this problem.. how are you connecting the router ?? usb cat5, do you have it on network ??? u need to supply more information
Jun 14, 2007 | Linksys WRT54GS Wireless Broadband Router...
Linksys Wireless-G WRT54G Router Logo
177 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
