Question about Garden
I have replaced the spark plug filters belt on my riding mower it will run for awhile then shut down. What do I need to check next or repair?
  • 10,865 Answers
Your carburator is gummed up. get some fuel additive called seafoam. Add it to your fuel and run your mower for a few minutes. this should clear your problem. if it doesnt you will need to rebuild the carburator. J.
Posted on Jul 10, 2010
Mower runs awhile and just quits like the gas is turned off. Changed gas line, filter, drained gas tank and changed air filter. Help
Next time it quits check for spark at the spark plug. You may have a failing ignition coil electronics which manufacture into the coil pack.
Apr 12, 2015 | Garden
John deere lx178
NEED VALVE JOB DONE MOWER IS OVER HEATING AND SHUTTING DOWN TO COOL OFF TO START AGAIN CHECK OIL LEVEL COULD BE LOW IF IS CHANGE OIL AND FILTER BUT GET VALVE JOB DONE BEFORE YOU SERIOULY DAMAGE IT VALVE JOB COST 100.00
Sep 01, 2014 | John Deere Garden
Starts but wont run and shuts down in seconds
Read entire posting before doing anything else first.
I discovered what the problem was, after changing spark plugs, fuel filter and air filter (At this point the mower would not start at all):
1. Checking for spark. I got spark out of both plug wires. The modules were OK.
2. Checking for fuel flow. Only small amount of fuel coming out of fuel pump. I changed the fuel pump. (I bought a Briggs and Stratton for $22.50 instead of a Kohler for $60.00. Same fuel filter!)
It ran fine for 10 min. then quit again!
I loosened the gas cap and it has ran fine since then, by keeping the gas cap loose. I will replace the gas cap.
Note: It was difficult to find the problem, since I replaced the filter and removed the vapor lock, so it ran for awhile. I then checked the fuel pump and removed the vapor lock, so it ran for awhile. I would suggest that people with similar problems, loosen the gas cap to see if that works first!
Sep 05, 2013 | Craftsman Garden
Craftsman 42
I had the same problem in my craftsman, the problem was in the choke. the spring was broken and it runs fine now after replacing the spring.
Aug 11, 2012 | Garden
Hi. I have a huskee 15.5 riding mower that wont start. It was running. I replaced the front drive belt and now it wont start. I have replaced the battery, air filter, and spark plug. it turns over fine...
fri-st is to check your spark, than your going need to check for compression, than go to carburetor, when you replaced your belt you may have disconnected a safety wire. try this frist let me know
Oct 06, 2009 | Garden
After the mower gets hot, it shuts down.
my john deere did the same thing i had spark and it did run,but the coil heated up an there was a short in it and it would stop and you wait awhile and it cool down and it would start again,i replaced the coil and the problem was gone.
Sep 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
