Question about Bowflex TC1000 Treadclimber
Bowflex TC 1000 treadclimber causing power surges that freeze the cable and internet and change the time on 1 alarm clock for 1-2 minutes every time I turn it on. What's causing this?
    President:
  • Bowflex Master
  • 832 Answers
You are not on a dedicated circuit the amp draw must be significant thus pulling down the voltage causing your grief. Find a and outlet that is not on the same circuit your electronic units maybe in another part of the house. Or put in a new circuit if you have a vacant in the breaker box, but that need a qualified electricians to do the job$$$$$
Posted on Jul 19, 2010
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
When I put my Bowflex tc 5000 at the highest speed it turns itself off in a minute. Does anyone else have this problem?
This sounds like something that had been happening to a treadmill at our gym.. The problem there was that the moving parts were getting too hot and thus, the machine swithes off to not start burning up/breaking both instances may cause injury to the user.. u need to have it checked by a professional
Jan 29, 2013 | Bowflex Treadclimber TC5300
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
Our TC 1000 stopped. We get the Error Code E1 when we try to turn it on. There is no sound or any movement. I don't know where to start. Help.
hi
ur treadmills speed sensor have some problem. pullout it clean it and then refix it. also check its white connector , is its connection is proper or not. if the sensor found faulty replace it.
ok
Dec 20, 2010 | Bowflex TC1000 Treadclimber
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Jan 29, 2009 | Bowflex Treadclimber
Bowflex Treadclimber tc 1000 turning off
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
Bowflex TC1000 Treadclimber Logo
179 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
