Question about HP Photosmart 3310 Printer
I have a system failed error code Oxc19a0013 - HP Photosmart 3310 Printer
    Scholar:
  • 103 Answers
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Posted on Jul 12, 2010
I have an HP and it says ink system failure Oxc19a0013 what does that mean.
remove the catridges and then unhook the print head. wipe with soft cloth. otherwise you need to replace print head
Aug 01, 2016 | HP PHOTOSMART PLUS B209A All-In-One...
Hp photsmart 8250 system failed error code Oxc19a0013
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Apr 13, 2015 | HP Office Equipment & Supplies
My laptop operating system failed to start it has an error code: 0xc0000001
It is probably a hard drive failure and will either require the operating system to be repaired, rebuild or at worst case the hard drive to be replaced and then the operating system to be reinstalled.
It is impossible to go further without expert examination so I advise you to find a reputable repair man.
Aug 21, 2014 | HP Computers & Internet
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Ink system failure Oxc19a0013 HP Photosmart B110
Check all of your cartridges to ensure that all of the protective tape has been removed. If you still receive the message after the check then power down your printer and remove the power cord from the back of the printer. Remove all of the ink cartridges from the printer. Wait 2 minutes, then plug the AC cord back into the printer. Turn the printer back on. Once the printer goes through it's power on self test it will ask you to insert the print cartridges. Go ahead and do so. If the error message does not display itself then you are okay to go ahead and use the printer. However, if you still receive the error display then you will have to have the printer serviced. Unless you have the tools, experience, and a copy of the service manual for your printer, it is best to have your local HP repair center take a look at the printer. The code signifies an ink system error, but there are a number of reason that can cause the error to display.
Mar 13, 2011 | Office Equipment & Supplies
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error message #Oxc19a0013----Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
1,823 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
