Question about Jandy AquaLink RS2/6 All Button Dual Equipment -
Pump runs twice daily, need to cancel one time
My RS6 pump is running twice a day. I recently changed the running time from 1PM - 3PM to 4PM - 7PM. While the screen says it is only set to run from 4-7, it stills runs at 1-3PM and 4-7PM. How do I cancel the 1-3PM cycle? I have tried everything and I can't figure it out - help! Thanks for any help anyone can give!!
Just press the cancle botton FIRST. Amazing no one posted a solution to this!
Posted on Oct 15, 2010
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
How do I cancel a program a program and reset a time?
go into system set up and go to set time reset and go to program then highlight what needs to be changed edit or remove program
May 02, 2014 | Zodiac Jandy AquaLink RS OneTouch RS6 Pool...
97 dodge ram 3.9 stops running while driving. if i sit a minute it will fire back up and run for days afterward....or maybe 10 minutes.
I had to change my fuel pump a second time after just 8 months It has worked fine since. It my be the fuel filter too.
Dec 28, 2013 | Dodge 1997 Ram 1500
This is a mechanical timer. The clock runs, but the timer never turns on the pump.
If the clock runs, the only thing left is the switches - and trippers.
If you can power up the pump by manually moving the switch from OFF to ON, that means the switches are good. The trippers are likely going to be the problem.
This timer needs white (or bright metal) "ON" trippers and black "OFF" trippers to turn the pump on and off at the times you select. The picture below shows a white ON tripper at 3PM (between 2 and 4) and a black OFF tripper at 11PM (between 10 and 12). This timer turns the load on at 3PM for eight hours and shuts it off at 11PM. You must have BOTH color trippers to turn ON and OFF. The trippers should be seated fully against the edge of the timer disc, and the screw tightened fully by hand.
More below the picture.
The manual can be seen here. Please rate my reply and good luck!
Dec 28, 2010 | Intermatic Mechanical Timer Switch - Pool...
How do i set my Hager time for outside lights for block of units. It has a dial. The instructions are not clear at all.
I am looking at the 31575 7-day timer manual
1) Set current day and time
The timer dial has numbers 1 thru 7 with oval circles around these numbers
1=Monday
2=Tuesday
3=Wednesday
7=Sunday
The oval numbers are located at 12 noon on each day
Since these numbers are circled with an oval, let's call them oval-1 oval-2 oval-3
Current time is always lined up with black triangle at top of dial
Right now it's Tuesday about 2am
Rotate dial until pointer is near oval-2 ... and then line up pointer with small number 2 (for 2am)
If it was 4pm, you would line up with 16 (using the European 24 hour clock)
If it was 8pm, you would line up with 20
2) Set your on-off times
The dial has segments around outer edge
Segments pushed-in = Timer ON
Segments out = Timer OFF
If you want the timer turned on for 2 days, you push-in the segments between those days
For example you want timer to turn on at 6 pm Tuesday and stay on until 3pm Wednesday
Push in all segments between those times.
Tuesday is located at the oval-2 ... 6pm Tuesday is at the 16
Wednesday is located at oval-3 ... 3pm Wednesday is is at the 15
So push-in all the segments between those two times, and the timer will turn ON at the scheduled time each week.
If you want the timer to turn on and off each day at same time, then you push in the same segments for each day.
For example the timer turns on your outdoor lights at 7PM and turns off at 11PM
Select a day: push-in segments between 19 and 23
Repeat the same for each of the other days and timer will follow same schedule each week
If you need more help, answer back and I will give words of encouragement.
Oct 26, 2010 | Hardware & Accessories
When the filter pump comes on, the cleaner booster
check the programs or better cancel all the programs and restar from the begining if still after this the spa side switch need to be replace
Sep 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Loss of signal
It is most lkely the battery, chane the battery and recharge it. batteries collapse after about 2 -3 years depending on use and abuse. If you have it plugged in when starting the engine the battery will deteriorate quicker and eventuslly fail. resting the battery can cause some charge to return, often sufficient to run it for short periods before it once again fails due to output being greater than the chrging rate.
Jun 30, 2009 | Tomtom ONE GPS Receiver
Not sure how long to run pump
First, RECYCLE is a position that allows water to continue to circulate through the system, BYPASSING the filter. If there is a problem with the system, like an air intrusion/leak, by putting the filter in RECYCLE you can determine if the problem is in the filter, or another part, of your system.
As for how long to run the pump, it can be ran 24 hours a day. Normally, the average run time is 8 to 10 hours a day. Most city codes require that pool water is "turned over" one time daily. This means that all of the water in the pool is ran through the filter at least once a day. Usually, 8 to 10 hours will give you that requirement.
Hope this helps!
Jun 06, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
273 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
