Home | GE | WBVH6240F Front Load Washer | Shuts off in middle of ...
GE WBVH6240F Front Load Washer
Problem for GE WBVH6240F Front Load Washer
Shuts off in middle of cycle
By Me_You on Apr 19, 2008
Our Ge washer shuts off at least 6 times during a wash. At no set time, just randomly shuts off. The clothes will be soapy at the end. I will have to rinse and spin several cycles before the soap will be out. At ,most times, the clothes are soaking wet. I will have to repeatedly drain and spin until finally they are ready for the dryer. I only use HE laundrey detergent. What can I do to fix this problem? I will never buy an HE washer ever again. This is a nightmare.
Same Problem
May 16, 2009
-   I also have the same problem. I just cleaned out the **** behind the white plug and ran a load. Worked great. The water wasn't able to drain, now it can. Thanks for all the help!!! -   Guest
Mar 27, 2009
-   i have the same problem;however the ge service man came out and said we needed to replace the pump for a few hundred dollars on a machine that is under 2 years old!!! ugh!!! any help or guidance would be appreciated here -   kathy4894
Jan 17, 2009
-   I have the SAME problem!!! I'm going to try the white plug thing to see if that will work.
It shuts off like 6 times a cycle, so I have to make sure I'm home when I do laundry or it'll just shut off and forget entirely what it's doing...soured clothes...yay :|-   Guest
May 23, 2008
-   The -   Guest
May 10, 2008
-   I have a GE Washer WBVH6240F. It will go into pause mode (start/pause button will be flashing) and will not continue until you hit the button to start again.-   Guest
Best Solution
posted on Apr 23, 2008
Very Helpful)
CJWATKINS
Rank: Apprentice
Rating: 97%, 9 votes
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Comments:
Apr 23, 2008
- Ok, service man came today---Easy solution
Take the panel off right under the round door(3 screws) there is a white plug looking like thing(like a gas cap) take that out(water will run out so have a bucket or towels or something) you will see all the muk muk around this plug clean it off and put back in.
My washer is running like day 1---yeah!!!!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Popular Solutions for GE WBVH6240F Front Load Washer
Questions and Unsolved Problems for GE WBVH6240F Front Load Washer
Do you recommend GE WBVH6240F Front Load Washer?
Answer
Answer
Water pours out from under the machine at initial fill. I can see it coming from the little valve... (More)
Answer
Once the add garment light goes out it starts emptying the water. then goes to the rinse cycle.
Answer
Hi Do you have any info on model WBVH5200Joww ? control board problem Thanks Angelina...
Answer
older model ge profile front load washer. door lock light is on load did not start?
Answer
We have cleaned out our filter and drained the machine. But when it is in a wash cycle it will not... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WBVH6240F Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14118
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
