Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Model rca r52wh74yx50
Loss of channel memory while watching channel 11 then have to re enter all channels.
  • meanjogrn Apr 25, 2008
    i still dont understand why the memory dumps all channels when loss of signal one one channel, and its one of the strongest signals in the twin cities.
    Sergeant:
    Champion:
  • 319 Answers
Consult owners manual for channel programming. Channel program sequence may be interrupted by weak or drop out of chl 11 signal. This happens occasionally when signal is from standard antenna
Posted on Apr 23, 2008
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
Why does my RCA f32632sb not receive all channels available? Other tv is fine. this one is an older model(free off of craigslist) and it won't get a bunch of channels. I have cable 2-57 in BC Canada. ANY...
I have a old RCA tv model F32632SB...and im having problems autoprogramming it...when I start the autopramming it starts on channel 14...after its done goingthru all the channels still no picture on all channels except channel 11...ive autoprogrammed the tv 50 million times still nothing... I tried the cable cord in another old tv and the cable is fine..anybody know ????
Nov 28, 2010 | Televison & Video
How do i delete channels from sanyo tv that i do not want to watch?
On my Sanyo DP50740 you, go to Menu, select Channel Setting, select Channel Scan memory, then just go to the channel in the list that has a check mark by it and push enter to remove the check mark and it will no longer show up when you flip through the channels but you can still access it by entering the number manually.
Nov 20, 2010 | Sanyo Televison & Video
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Mar 06, 2010 | RCA 27V520T 27" TV
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
I get 110 direct to receiver or 119 direct to receiver (dish 500) but when I use the sw21 switch I only get one
Hi
Thanks for using FixYa. As per the issue you described, I think you are not able to switch to Channel 21. It means that it has either been deleted from the projection TV or you have set the parental control guides. To correct the former, access the Channel controls by pushing the "Menu" button and maneuver the channel icon, then press "+". Select "Favorite Channels," and then the "+" button again. Then type the number of the channel (21) you are not able to watch and press the "+" button one last time. To access the parental control channels, press "Menu" and maneuver the Parent icon, and press "+." Enter your four-digit password and use the arrows on the remote to change the overall settings. After performing this procedure hit the "+" key one more time. Now you will be able to watch channel 21 as before.
Please tell me the model number of your Unit so that I can provide you with model specific information.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | RCA DISH Network(r) 311 Satellite System
Channels
Hit the menu button, find and enter setup (or channels)
Choose cable or antenna (what you have)...... then make the set "autoprogram". It will add all channels into the tv memory.
Mar 25, 2008 | RCA 20F420T 20" TV
Channels will not change
Do a auto program from the menu. If the set has lost its memory from a power loss or other situation it will loss it memory of what channels you have and unless you put the channel in from the remote it will default to ch 2
Mar 07, 2008 | Proscan 32LA30Q Television
RCA f27242gy
If you have a remote control you should be able to access the "atuoprogram" feature within the setup menus. This will look for all active channels and place them into memory. What model is it?
Feb 04, 2007 | RCA F27242GY 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
