Question about RCA VR622HF VHS VCR
I have an old rca vcr plus and I can set a timer recording but I can't find the clear button to clear the program. I orginally set the program to record m-f at a certain time but now I don't want it to do that anymore but if the recorder is off and I happen to have a tape in it it starts recording at that time. The onscreen message says to push clear for a program I don't want anymore but I have pushed every button on the remote because there is no 'clear' button and nothing clears the program.
  • 579 Answers
SOURCE: RCA VR688HF VHS VCR won't accept tapes
The brain in a VCR has a little switch assembly that senses what position all the mechanical stuff its in. Apparently, the mech is out of whack which is why it won't let you play. This is a common problem and any VCR shop should be able to repair it.
Posted on Dec 28, 2007
Coldcut
  • 1554 Answers
SOURCE: i need a 3didgit code for my one for all remote i have a rca vcr plus home theater series
http://www.ofausa.com/product_support.php
click on type
and download manual
Posted on Apr 02, 2008
  • 78 Answers
SOURCE: recording issue
if it is really old there might be a switch on the front under the little door to switch record speeds.
Posted on May 03, 2008
ahhsoo69
  • 167 Answers
SOURCE: VCR does not eject tape correctly
hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
SOURCE: timer flashes constantly and vcr wont work
If you still need a remote let me know. I have one. claudia_sisson75@yahoo.com
Posted on Feb 21, 2009
How to turn off timer setting and put in a new program
Hit the menu key and select the recording options. Select the option to view timer recordings and select each one to clear it. Follow the onscreen instructions or when on a recording hit the clear/delete button on the remote.
Feb 19, 2014 | Rio Go Video SDV-650 S-VHS VCR
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
How can i program a VCR plus with out a remote the timer light keeps flashing
Generally the timer flashing means that ethier a programme for recording is set to record or wrong information is added. You need to check the timer record menu to see if a recording is schedule. I suggest you might need to get a remote for the model or get a universal one. Placing a blank tape in a powering down, should see the timer stop, but if a recording schedule is there it will still be on. The only way to clear it (without the remote) might to let it record! You don't give the make or model so I can't say anymore.
Jan 17, 2011 | RCA Televison & Video
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Clearing program
You are in a tough spot cause you probably keep the VCR to transfer old Tapes. FYI, did you know that DVD's have a shelf life of less than 10 years and VCR VHS tapes are good for 20 years plus? Keep your old tapes.
Write RCA and find out if you can get a new remote, it is basically the only solution.
Check with Ebay for a used one, you might get lucky.
E
Nov 11, 2008 | RCA VR349 VHS VCR
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Sep 12, 2008 | RCA T13208 13 in. TV/VCR Combo
How to set the vcr to record
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Feb 06, 2007 | Hitachi VTMX4510A S-VHS VCR
RCA VR622HF VHS VCR Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
