Question about Associated Electrics CVD Axle Pins 18T 18MT
Need to remove front axle for replacement, 1993 Mercury Villager, 6 cylinder, it is attached to transmission need to remove bolts for back joint
  • 4,382 Answers
Change
what a great question.
that depends on skill and tools.
i remove the engine. (i have a motor lift and is so easy)
got ramps.
got lift
got pit, l got stands. got tranny jack.
got muscles.?
at alldata.com is the FSM and for $15 you can read the factory way.
Jun 30, 2013 | 1993 Geo Metro
I need to know the torque-specs on the bolts for the CV shaft on a 1993 90 s. I need both the specs for the 6 bolts that hold the cv shaft to the transmission, as well as the 1 big outer-spindle...
Axle shaft bolt should be torqued to 147 Ft Lbs plus 1/4 turn.
The six CV joint bolts should be 59 Ft Lbs.
Ball joint nut should be 48 Ft Lbs
Hope this helps.
Sep 08, 2011 | 1993 Audi 90
HOW TO INSTAL QUICK STRUTS ON A CHEVROLET MONTE CARLO 2003
Hello dedime,
Removal
1. Remove the nuts and bolt attaching the top of the strut assembly to the body.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Place jack stands under the front cross member.
4. Lower the vehicle slightly so that the weight of vehicle rests on the jack stands and not on the control arms.
Notice: Care must be exercised to prevent the drive axle joints from being over-extended. When either end of the shaft is disconnected, over-extension of the joint could result in separation of the internal components and possible joint failure. Drive axle joint boot protectors should be used any time service is performed on or near the drive axles. Failure to observe this can result in interior joint or boot damage and possible joint failure.
5. Remove the tire and wheel assembly.
6. Remove the brake line bracket.
7. Scribe the strut flange.
Important: The steering knuckle must be supported in order to prevent axle joint over-extension.
8. Remove the bolts and the nuts attaching the strut to the steering knuckle.
Notice: Care should be taken to avoid scratching or cracking the spring coating when handling the front suspension coil spring. Damage can cause premature failure.
9. Remove the strut from the Vehicle.
Installation Procedure
1. Install the strut into position and install the nuts and one bolt connecting the strut to the body. Hand tighten the nuts and the bolt.
2. Align the steering knuckle with the strut flange scribe mark and install the bolts and nuts. Tighten the nuts to 180 Nm (133 ft. lbs.).
3. Tighten the nuts and bolt attaching the top of the strut to the body. Tighten the nuts to 25 Nm (18 ft. lbs.).
Tighten the bolt to 25 Nm (18 ft. lbs.).
4. Install the brake line bracket.
5. Install the tire and wheel assembly.
6. Inspect the front wheel alignment.
Regards,
netvan
Feb 22, 2011 | 2003 Chevrolet Monte Carlo
I need to remove my front axel on my 1989 toyota camry
Jack up car and apply e-brake. car will roll if one of the front tires leaves the ground. remove tire , spindal nut and lower ball joint bolts. remove axle from hub then use a prybar to pop it out of trans. the passenger side will have a braket holding axle to engine , remove bolts from braket or squeeze snap-ring to rmove axle from braket.
Jan 11, 2011 | 1989 Toyota Camry
I need firing order of piston on a 3.0 in a 1993 mercury villager
For the 1993 Mercury Villager 3.0L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)......
|...1....3....5...|
|...2....4....6...|
......(front)
Distributor:
..(back)
.....2
3........1
4........6
.....5
(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
May 29, 2010 | 1994 Mercury Villager
How to remove a transmission?
Hope this is not your first, if it is you picked a tough one to learn on. Here goes:1 disconnect negative battery cable 2 Raise and support the car, a lift is the best tool for the job here, but you can do this on jackstands, they just need to be tall ones at least 2 feet of clearance under the car. 3 Install engine holding fixture, this supports the back of the engine when you remove the crossmember and trans.4 remove left front wheel, seperate ball joint remove drive axle retaining nut then remove drive axle from transaxle by prying at joint closest to transaxle. Do not pull on the outer joint or you will pull the inner joint apart. 5 place transmission jack under transaxle pan. 6 remove bolts from crossmember then remove the crossmember 7 remove inspection cover then remove three torque converter bolts 8 remove transmission cooling lines from fittings on transmission 9 remove shift cable 10 unplug 4 wire plug from front side of transmission 11 remove 6 bolts from bell housing 12 remove speedometer cable 13 remove three bolts from around right hand drive axle, then pry axle loose from transmission. You do not need to remove axle from car, just let it hang.14 pull transmission away from engine far enough to disengage the alignment dowels and finish pulling right hand drive axle from transmission housing then lower the transmission to the floor 15 pull transmission from under vehicle.
Mar 16, 2010 | 1998 Chevrolet Cavalier
Rt front axle broke how to repair
If there is no other damage aside from the outer CV joint being out.
1. Jack car up and support on jack stand on the affected side.
2. Remove wheel
3. Remove center hub nut
4. Turn wheels all the way to one side or the other. This is to gain access to the lower ball joint. One way will be easier than the other depending on how the bolt is installed.
5. Remove lower ball joint bolt and nut
6. Separate the ball joint by using a large pry bar or pipe to push the control arm down and hit side of joint with hammer.
7. Once joint has released pry down to free control arm from ball joint shaft.
8. Now tap the outer cv joint part still trapped in the hub out
9. Remove remaining axle from transmission by using a pry bar to pry it out of the transmission.
10. Reinstall new axle into transmission and then start into hub. Make sure to shove axle firmly into transmission so as to get past the C-clip lock.
11. Pry lower control arm down to allow the ball joint to be reassembled. Slip ball joint shaft back into control arm.
12. Reinstall bolt and nut
13. Install hub nut
14. Install wheel
Jan 24, 2010 | 1994 Pontiac Bonneville
Master cylinder
unscrew the lines and undo the two bolts that hold the master cylinder in place. it will come right off.
Feb 01, 2009 | 1993 Mercury Villager
I need to change an axle in a 1993 nissan altima
the axle nut should be a 36mm
will also need a 17mm to remove three bolts holding ball joint to control arm and a pry bar to pop axle out of transmission. if replacing right side will need tounhook support bearing
Oct 10, 2008 | 1993 Nissan Altima
Associated Electrics CVD Axle Pins 18T 18MT Logo
61 people viewed this question
Top Associated Electrics Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Associated Electrics Toy Expert? Answer questions, earn points and help others
