Question about Tomtom ONE GPS Receiver
Sd card doesnt read
My tom tom -no longer reads my sd card-it seemed to happen within a day or so of me downloading some software_ive tried the card on two diff sat navs -still no joy.
The reset pin makes no difference.
  • 518 Answers
Just an idea, make sure the small switch on the lefthand side of the SD card is in the up position, if it is down the card will be locked, Not a solution, but worth a check.
Posted on Jul 11, 2010
Can anyone help me restore my sd card and its memory . Okay. Well first off my sd card won't mount period I tried resetting it and everything . I tried to add a picture to facebook. But it says USB cord...
sounds like the mem card is ruined, if you took mit out without un mounting it this can happen, download scandisk memory manager, withe the card installed run the app, if it doesnt find it the card is no good and get another, try the phone with the new one and should be ok
Oct 15, 2013 | Cell Phones
Camera reads communication error when trying to upload photos what might be the prob
I BELIEVE THE REASON IS THE TYPE OF SD CARD.
THERE ARE SD AND SDHC. IF YOU ARE USING SDHC.
I BET THE ONE CARD THAT DOESNT READ IS AN HC. THIS IS ALSO TRUE WITH OLDER CARD READERS. I HAVE AN OLDER AND NEWER CARD READER.
I JUST HAPPENED TO PUT AN OLDER SD CARD IN MY NEW POWERSHOT SD1300 AND IT READS FINE, ALL NEW CARDS SDHC WONT READ.
I BELIEVE SD IS UP TO 2GIGS AND SDHC IS 4GIGS AND HIGHER.
Aug 24, 2010 | Canon PowerShot SX120 IS Digital Camera
I can't get the dish to re format. Error meassage reads disk problem and a x in a red circle appears.
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
The SD card may also need formatting properly.
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Oct 11, 2009 | Tomtom ONE GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Samsung J700 memory card problem
that unit only reads a 1gb of memory card
Aug 23, 2009 | Samsung J700 Cellular Phone
My env2 wont read my memory card!
this also happened to my phone its not the memory card, its the phone...check if any of your front keyes on your keypad are broken too. Mine where and it was as if the memmory card didnt exist. If this happens you have a 1 year warranty with verizon and you can get a new env2 which is what i just did. they sent me a new one and it works perfectly.
Apr 11, 2009 | Verizon Communications enV2 Cellular Phone
TOM TOM ONE (great britain)
Looks like corrupted software / files on your sd card. if you made a backup of the card to your PC ( I hope you did ) try formatting and re-installing the files onto the SD card.
Nov 04, 2008 | Tomtom ONE GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
Apr 01, 2008 | Tomtom GO 910 GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
146 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
