Question about Jenn-Air JSD2690HES Stainless Steel Side by Side Refrigerator
Refrigerator compartment freezes food - Jenn-Air JSD2690HES Stainless Steel Side by Side Refrigerator
    President:
  • 2,702 Answers
The thermostat has stoped working,,it need a new one fitted,,,
often the thermostat stayes switched on when its packed up working to save the food in side it,,,,
Posted on Jul 10, 2010
I have a model BX21/BC21 and the refrigerator compartment is freezing some foods. What is desired setting for refrigerator compartment and freezer compartment for this model?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 30, 2011 | Amana Refrigerators
Freezer compartment freezing too much even when fridge turned down to 1 - how can we turn off freezer compartment as doesn't seem to have a seperate control Thanks
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 21, 2011 | Refrigerators
Kenmore Elite refrigerator model # 106.74206400: freezer compartment working fine, refrigerator compartment about 20 degrees too cold. Found a method for running a diagnostic: 1 and 2 passed, 5 failed. ...
heatman101
Jan 12, 2011 | Refrigerators
Food is freezing in the Refrigerator compartment
heatman101
Dec 31, 2010 | GE Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Food in bottom compartment freezing food
you have the air flow regulator in the bottom of the fridge close to bottom compartment wide open experiment by closing it gradually till you have the desired result.
Sep 18, 2009 | GE Hotpoint Top-Freezer Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
Food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Jan 25, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Jenn-Air JSD2690HES Stainless Steel Side by Side Refrigerator Logo
140 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
