Question about Lands Phones
Phone model DXA/4588-2 What frequency is my phone operating on? Can it be changed?
Forgot my pin number
You can reset the PIN following the instructions on page 35 of the manual: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI5588-2om.pdf
Sep 06, 2014 | Uniden Cordless Phone
How do I change the channel?
The owners manual should tell you how to do that. If you don't have the manual, search online for the type and model of phone you have. There should be a way to get the manual mailed to you or download it online.
Jun 27, 2014 | Uniden Cordless Phone
Panasonic KX-TG2631al 2.4GHz cordless phone is getting interference from crossed lines from another phone and wont receive or make calls
No you need to purchase a device that operates on a different frequency-most hose phone do not change frequencies beside the Bluetooth ones, and it seems your is not. I suggest a 5.8ghz and a store that has a flexible return policy, RadioShack has a decent selection of phones around 50$ give of take, you could also go for a Bluetooth setup--Good Luck.
Jan 31, 2013 | Panasonic KX-TG2631 Cordless Phone
Model DXA 15588-2, What procedure is necessary to "Play Messages from a Remote Location"? Our default PIN Code is 80. When I call my machine, when and how do I enter this Code? Thank...
At the greeting, press 0 and then your security code.
The full instructions are in the "Remote Operations" section beginning on page 46 of the manual at
Jun 06, 2011 | Uniden 2.4GHz Cordless Phone w/Digital...
Can you operate two base stations in parallel on a single line?
Yes, although if they are the same frequency there will most likely be interference. If you can change the channel(s) and/or operating frequencies you could try that.
Apr 21, 2011 | Vtech CS5121 Cordless Phone
We have an old Uniden phone Model DXA 15588-2. We need instruction to access the messages away from home. Thanks, Karen Moore
Follow the instructions in the "Operating the Answering Machine While You Are Away From Home" section beginning on page 11 of this manual.
Jan 20, 2011 | Uniden Cordless Phone
My phones don't work they all say
Unusual problem on a new phone. Could possibly be radio frequency interference close by.
Some cordless phones operate on the same frequencies as in-home wireless networks. I believe this is the 2.8 megahertz frequency. The phones and the wireless networks can interfere with each other.
Most newer cordless phones are higher frequency (5.8 megahertz?). Wireless networks shouldn't interfere with those phones, but there could be other things that could (e.g., transformers on power poles).
If the phones are new, you might consider taking them back and getting another model.
Oct 10, 2009 | Uniden Cordless Phone
KX-TG2632 causing static to my baby monitor.
Baby monitors apparently are all on 2.4GHz frequency range. Phones have to be either beneath ie 1.8GHz or above eg 5.4GHz and no interference will occur. So simply had to change the phone because its frequency range was 2.4GHz.
May 27, 2009 | Panasonic KX-TG2631 Cordless Phone
Uniden DXA 1388-2 Cordless Phone
Couple different ways -
1- get a recording device from Radio Shack that plugs into the handset to record calls and playback to record.
2. If you have a computer record it through your windows operating system
3. use your cell phone and record it
Then you can download it as a recorded file into anything you desire.
Nov 13, 2008 | Uniden Cordless Phone
Phone
Hi - You can download the manual by clicking the link underlined in blue below:
dxa 1388 2
See page 23:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 23, 2008 | Uniden Cordless Phone
Lands Phones Logo
93 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
