Question about GE (PSS26MSRSS) Side by Side Refrigerator
Everything in the freezer defrosted because i left the freezer door open for about 8 hours how long will it take to refreeze i feel the cold air blowing inside the freezer. its been 4hours already
  • GE Master
  • 3,051 Answers
Hello there:
If every thing has been defrosted it should take about 6 to 8 hrs to fully freeze again now that is also depending on how you have the freezer temp set i would set the temp so that it gets the coldest that it can than after the food has frozen than reset it back to you setting that you had before ok
Hope this is very helpful for you
Best regards mike
Posted on Jul 10, 2010
GE GSL25JFXB LB refrigerator is not cooling. Freezer working fine.
all this machine does is get cold in the freezer and the evaporator fan in the freezer blows the cold air over into the fridge section,so first off open the freezer door and listen for the fan,if you don't hear the fan i would change the fan motor and this has a mother board in the back,if you never had this board changed out and this machine is over 8 years old most likely you don't have the newest board in it so i would replace the board too,you can unplug it and look at the board,you'll see black relays on the left side of it,if your board doesn't have all the relays in it you don't have the updated board in it,even if the fan is blowing and you don't have the newest board in it you should get the new board and install it.if the fan is blowing pull out the second bin or draw starting from the bottom up and reach in and touch the back inside wall of the freezer,if you have frost or like ice buildup on the back wall you have a defrost problem,bad board,bad defrost heater or also there's a sensor in the freezer at the top of the evaporator coil,it looks like a white bullet,if this has a black ring around it where the wires connect to it you have to change it out,g.e. had problems with this sensor the new sensor is all white,also look at the heater,if you see all black inside the glass heater change it out,if you want you can write back to let me know what you find or if you see these parts that i told you about that are bad change them out.good luck.one more thing,if you unplug it,take everything out of the freezer,remove the back inside wall of the freezer,if you find it's not defrosting you can melt out all the ice with a hair dryer and the fridge will work for like 10 to 14 days until the coil refreezes so if you find ice on the back wall then you have a defrost problem or if there isn't alot of ice the door could have been left open and the air ducts froze up,there's one more thing,in the fridge section you have a damper,all it is is a door that opens to let the cold air blow in from the freezer,if the damper is bad and the door doesn't open then the damper is bad,open the freezer if you hear the fan blowing but the air isn't coming through the damper it could be the problem,i know it sounds like alot of things to check but it doesn't take to long to check it out.just remember all that's happening is the fan in the freezer blows cold air over to the fridge so either the fan motor is bad,bad damper or defrost problem.
Dec 31, 2017 | GE Refrigerators
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
Bottom freezer was left open and things partially defrosted. Now I cannot get them to refreeze. The items are still partially defrosted and it has been four days.
The fan that blows cold air into the freezer may be blocked by ice that built up. See if you can find the area where the fan is located and open it to look inside. You may have to completely defrost the freezer to eliminate the ice and free up the fan to turn.
Aug 22, 2009 | Refrigerators
The freeze section is colding fine but the other half is not.
The Ref side is basicly an insulated box, all the cooling coils are in the freezer that's why they put a fan in the freezer to force some of the cold air over to the Ref. side. There is a small opening between the Ref and Freezer with a door. This door is controled by one of the two settings on the Ref side. One of the controls is for the Temprature usually 1 thru 9 with 9 being the coldest and the other controls the little door. Now, why is that cold air in the freezer not going through that little door?
1. The little door is not open wide enough.
Turn your control to open the door wider. This control may be labeled "Freezer" so, when you turn it to the "Coldest" this closes that little door and makes the freezer "Coldest".
You can't see this little door but you should be able to find where the air comes through and feel the cold air, that is,if the fan in the freezer is working. If everything in the freezer is working and you can't feel any air coming through then your "little door" control is not working.
2. Fan in the freezer is not working.
This is pretty easy to check, open the freezer and listen for the fan running.
3. The cooling coils in the freezer are clogged with ice which won't allow the fan to circulate the cold air over to the Ref side.
On a side by side you can take out the bottom drawer and get a partial view of the coils in the back however, to get a full view of the coils you must take everything out of the freezer, romove the shelves, remove the back pannel. You should be able to see the drain at the bottom right under the coils. This area should be clear whit nothing bolcking the drain hole in the middle.
The coils will normally have a light coating of frost but should not be completely clogged with ice. If they are clogged then your defrost system isn't doing it's job.
Defrost System consist of a defrost timer, heating coils, and a thermal disc. You will need an OHM meter to check these and I can give you more details on how to use the meter and how to check the defrost system. ronbuice.com
Nov 30, 2008 | Refrigerators
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
