Question about Amana AFD2535DES French Door Refrigerator
The refrigerator door was left ajar and now it is not keeping the food cold.
    President:
  • 2,702 Answers
Try turning the thermostat up a little,,,if this dont work you may have busted the compresor,,,after all the fridge was only made to keep a small space cool,,,,not the hole house!
Posted on Jul 10, 2010
LG french door refrigerator does not keep food cold. Left door pops doesn't stay tightly closed.
What do you mean by "pops"? If your problem is the door, then it is possibly leaking out your cold air. It could be the seal or the hinge.
Aug 11, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
What to do about LG french door refrigerator that does not keep food cold
I would suggest you check the seal and the hinge. This frig has a piece that folds in and out flush for the two doors to seal, you might check that as well.
Aug 11, 2014 | LG LRFD25850 French Door Refrigerator
The refrigerator door ws left ajar for several hours will this damage the refrigerator.
No, but it may take a few days to settle back down and keep an even temp. again...you may also see excess water when it defrosts.
heatman101
Apr 21, 2011 | Maytag Refrigerators
Accidentally left freezer door ajar when we left for the weekend. Emptied all contents. Freezer seems to be OK, but refrigerator compartment is not getting cold. Ideas?
until the "fabric" of the freezer reaches -18c the fridge will seem to be not working.leave it to settle for 24hours.....keep the doors shut.
Aug 24, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The refrigerator is not cold only cool. the freezer door got accidentally left ajar and got ice build-up on the food. Ever since that the refrigerator portion is only slightly cool not cold. I moved the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. The ice may have also stopped up this opening blocking the air flow.Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Refrigerators
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
182 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
