Question about Sony PlayStation 2 (PS2) Console
Hello for some reason my PS2 isn't working I've tried shifting it horizontally airing it out (i.e out of the way of other objects) using a fan and even making sure that the plug was in and it was working but for some reason the red light won't turn out. Can someone please help me?
    Champion:
  • 273 Answers
If it's a slim PS2, try unplugging the AC from the wall and wait 5 minutes before plugging in.
hope this helps :D
Posted on Oct 13, 2010
The game cannot be read on our ps2, but the ps2 works for other games. the disk looks fine. what can we try to get this game to play?
Even if the game isn't scratched, you should try holding it under a light to see if there are any fingerprints or smudges on the disc. You can try cleaning the disc with a lint-free cloth if you've got one, though I've never had trouble with a cotton t-shirt. Wipe from the center of the disc straight towards the outer edge. Do this for the entire disc and try it again.
If that doesn't work, please update this issue with the error message you're seeing if any. Does the disc show up in the PS2 browser? Do you get a disc read error? Does the screen just go black when you try to play the game?
May 04, 2012 | Konami Yu-Gi-Oh! Duelists of the Roses for...
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
Jan 17, 2012 | Refrigerators
I own a 2004 Hyundai Accent. When the car is in park I'm not able to shift out of park. I've use the over ride but now that is not working. H E L P !
Hello! The Brake Light Switch is the likely culprit...Check fuse # 8 (10A) Dash fuse box first...On the Brake Switch connector; The Pink/Black wire should have 12 volts when brake is depressed...If it does the second choice is the Shift Lock Solenoid isn't pulling...Lets check the first choice and eliminate it before moving to the next...Send a comment...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 15, 2012 | Hyundai Electronics Hyundai Elantra 2004...
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
My old ps2 controller is not working. i used a new controller but it still doesn't work. the new controller was tested on another unit and it works fine. so i guess its the console itself is the...
See if your ps2 controller hub or port is damaged. If any pin is twisted try to get it straight and if you can't fix it, take the console to a service center.
Oct 13, 2011 | Sony PlayStation 2 (PS2) Console
Laptop when turned on display on screen "fan
When the laptop or PC is used, its processor and RAM gets heated. To keep it cool, a fan is used which circulates the air in the board. If there is no cooling system in the laptop, its circuit could be damaged by over heating. I think the fan in your laptop has malfunctioned or it is jammed by something. Turn over your laptop and try see if there is anything stuck in the blades of the fan. If there is anything, then take it out and then try to start your laptop. If there is nothing, then there is high possibility that the fan has malfunctioned. It would be better if you take it to service centre to get it repaired. Hope this helps you!!
Aug 16, 2011 | IBM ThinkPad T43 Notebook
My Amana refrigerator just stopped cooling the lights work there is air blowing but not cool...what can I do?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons The fan or blower has failed. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again. The second reason can be more difficult. 1. The timing device that runs the defrost cycle of the refrigerator is defective. 2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good. The timing device can be an advanced defrost control board or a mechanical timing device. If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things. The fan or blower The timer device The electric heater coil By methodically checking these parts you can isolate your problem and fix it.
Good luck in solving the problem....
Aug 07, 2011 | Amana ABB1927DE Bottom Freezer...
My compressor goes on, but the fan doesn't turn and the top of the fan housing gets hot.
Hello, try to use a thin object and spin the fan blade, if this getsnthe fan going then most likely the capacitor is bad and must be replaced. If this does not get the fan going then the motor is shot.
Aug 05, 2011 | Goodman CKL60AR60 Air Conditioner
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
Sony PlayStation 2 (PS2) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
