Question about IBM ThinkPad A30 Notebook
My laptop had been working fine, then the last
My IBM ThinkPad A30 laptop had been working fine, then the last time I tried to boot it I received an error message that said: windows/system32/hal.dll is missing. It wouldn't do anything after that. I tried the Windows XP cd repair....nothing, I tried to reinstall Windows.....nothing, I tried to reformat the hard drive and received an error that it couldn't reformat it. So I went to the c prompt and did a reformat. Reinstalled Windows, of course all my info/drivers are missing. But my main problem is that I can't use the run box to install updates or drivers. All I get when I type in a command is a black box flashing for a second then it takes me back to the desktop. Can anyone help me with this?
  • mydogbuster3 Jul 10, 2010
    Are you telling me to reinstall Windows????
  • 487 Answers
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Posted on Jul 10, 2010
How can i reset bios password of ibm thinkpad A30 2652
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Feb 02, 2011 | IBM ThinkPad A30 2652 Notebook
Dose all ibm have wireless connection in them
No all ibms dont have wifi built in,,check ibm website to see if your model does,,also jus search online ,,,ibm thinkpad a30 2652 did it come with wifi,,should find answers,,thanks,,goodluck
Nov 20, 2010 | IBM ThinkPad A30 2652 Notebook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
IBM thinkpad t42 boot up problem.
The sympton is rather vague, but I suggest the following options, to be followed one by one, until one of them works for you.
1) Boot your system in Safe Mode (if Windows is your OS) by pressing F8 after the usual "beep" provided by the BIOS after it detects all is fine. If it boots up, which takes a little longer than usual, then your system is probably Ok, although it may have a configuration problem.
Reboot the machine from the shut down menu and hopefully it will work Ok. If not, then, depending on whether you have Windows Vista (or better), try:
2) Boot again pressing the F8 key, but this time locate the option that reads something like "Last known good configuration". Highlight it with the arrow keys and press Enter.
If you have System Restore set on your drive(s) your laptop should boot up normally.
3) The last option would be for you to go into your system BIOS and run at least a HD detection test, followed by a memory test, etc., but I would only recommend doing this if you know what you're doing. If not, ask a friend for help.
Aug 17, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
PROBLEM WITH IBM THINKPAD A30-- VIDEO DRIVER NOT FOUND
the new video drivers require your Thinkpad to have BIOS version 1.14 or higher so update bios or download an older ati driver.
Jul 08, 2008 | IBM ThinkPad A30 2652 Notebook
Hi sir.. can u fix my ibm thinkpad A30
Here's a link to IBM's video drivers. You might have to try several before finding the right one. Keep in mind that it doesn't have to have your particular model listed in order to work properly.
http://www-1.ibm.com/support/search.wss?rs=0&lang=en&loc=en_US&r=10&cs=utf-8&rankfile=0&cc=us&coll=0&spc=&stc=&apar=include&q1=thinkpad+a30&q2=video+driver&sort=rk&tc=&ibm-search.x=12&ibm-search.y=14&dc=D400&dtm
Jul 08, 2008 | IBM ThinkPad A30 Notebook
Ibm thinkpad A30 2652
Some of the older thinkpad had a program you from the OS or a boot floppy to had to run to get change the bios settings. But the BIOS key on most is F1. So if you press that key as soon as you turn the machine on and anything appears on the screen, and once you've provided the password you can then change the password to blank within the bios.
If you don't know the password at all, there may still be a way to reset it, but it may require a call to IBM/Lenov, or some other tedious process.
Feb 02, 2008 | IBM ThinkPad T40 2373 Notebook
Open Questions:
IBM ThinkPad A30 Notebook Logo
108 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
