Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Where is the egine model number located on a Lawn
Where is the engine model number located on a Lawn Boy mower with a Dura Force engine?
    President:
  • Briggs & Str... Master
  • 1,545 Answers
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
Posted on Jul 11, 2010
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
I need to download an owners manual 10323 lawnboy mower
Hi Nancy,
here is a link to a page that should help. It looks like you may have to purchase the download:
https://lookup3.toro.com/request/sendreq.cfm
Good Luck!
Jim
May 25, 2016 | Garden
There does not seem to be a spark. I even put fuel
is the deadmans handle pulling the cable enough to cancel the off switch? if not relase the cable from the handle, TIE A KNOT IN IT(!), re fit to handle, & bingo!
If the cable is working well enough already DONT tie a knot, it wont help, its the ignition coil! ( around £30)
Apr 02, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
What is the spark plug gap setting for a LAWN BOY DURA FORCE engine 2-cycle 6.5HP?
from what I have seen so far the gap is .30 for all manual start 2 cycle and 4 cycle and .35 for electric start
Mar 11, 2010 | RTO Lawn Boy 6.75hp Mower
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
My Lawn Boy Pull Start is Locked Up... If I take the Pull Start off, it is fine. How do you know if it is the motor. I am able to get the blades to turn by hand. They do not turn easy like a windmill, but...
Remove spark plug before you ever try to turn engine by the blade then turn engine. If it is hard to turn your cylinder it is gaulded and needs to be serviced or replaced. Check with a professional repairman. Did you run engne low on oil?
Jul 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
327 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
