Question about Sub-Zero 680 / F
Fridge too cold
Temp suddenly dropped below freezing. cant seem to get it back up
    President:
  • 2,702 Answers
Its a faulty thermostat,,its stuck in the on poshion,,, thats how they fale most of the time so as to save the food inside them,,,,they then freez solid!
Posted on Jul 10, 2010
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
1 year old kitchenaid kbfs25etss01. all of a sudden the fridge temp is up to 55 degrees. i did put a bunch of water, soda and beer in the fridge tonight. is it blocking something? door seems shut.
Watch the unit for at least a hour, to see if the temps drop. You could have had the door open too long and lost a lot of air. Normally, they can recover from this, and this is nothing to worry about. I loaded my today also and my temps went up to 45, but my door way open for about 10 mins or so. Don't check the unit for at least 1 hour. Allow time for the system to recover. It should be ok. It should be able to drop temps with in a hour or a least 10 degrees.
Get back to me if you have any more question or concerns.
Good Luck, enjoy your cold beer....
Aug 17, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
I have a Liebherr fridge which seems to be on permanent supercooling. It freezes fluids. I try setting a higher temperature but it just drops back to 4 C
4c is the std operating temp for most fridges.have you checked the door seals for fit if an airleak occurs fridge will try to maintain cooling.....freezing salads.
Feb 11, 2010 | Refrigerators
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Fridge temp will not drop to set temp
if you have had a sudden power failure or power spike, you may need to reset the fridge. This can be done by holding down the power freeze button and the fridge temp button together for about 5 seconds. The fridge display will go blank. press the buttons together again, the fridge display should return and both fridge and freezer should be reset
Apr 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
Water dispenser keeps freezing!
it sounds as though there is an cold airflow problem in the fridge and as science states the cold air will drop down to the bottom of the fridge. check that any circulation fans are not jammed with ice or faulty. if not sure where to go do a defrost for 36 hours and check on all the functions after that. tone.
Jun 04, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
175 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
