Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
Just need to ask, trekstor external HD light is
Just need to ask, trekstor Datastation maxi m.u Model no. DSMMU-S-SU-a light is flashing blue/red, with clicking sound, is drive dead? My PVR wont recognize it anymore, btw this all happened after a power failure, unit was on at the time.
  • 487 Answers
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Posted on Jul 10, 2010
  • Paul J Jan 02, 2012
    Had the same problem. I changed the power cord/supply and it worked
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5" External Hard Drive 1TB & USB 2.0 on the floor. When I turn it on the light illuminates however when I plug it into my computer it doesn't even...
Mechanical damage. Last possibility to retrieve the data on it: open the case, extract the hard disk, put it in a desktop and try to access it in there. If even this fails then it's dead, junk it.
Feb 04, 2011 | Trekstor 88470 DataStation duo w.u 1TB...
My 750GB TrekStor external HDD failed. The light at the front of the device went from BLUE to RED and the machine seems to start to boot up the clicks a few times and then nothing. I cannot view the...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
I have a external Trekstor DataStation maxi 500 Gb hard drive. I now have encountered a constant red light and when this happens the drive is not visible in Explorer. When I turn off the power and then...
At the least, the device is "unreliable", and it would be wise to replace it, either by exercising the warranty (if the warranty still is valid), or by opening the enclosure, removing the disk-drive, buying a new (and compatible) disk-drive, inserting the new disk-drive, and closing-up the enclosure, to create a "new" external storage-device.
Sep 18, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
The HD start with blincking the front led from red to blue, it has a soundclick and is not recognized by the PC as a unit disk. Until now it was running well. I have a very critial dat ainto it and the...
Sorry, what you hear is the so-called click of death - the reading head is no longer capable of reading the data on the disk. This in unfixable and all the data on the disk is lost.
Sep 01, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Datastation m.u stopped working : (
Dropping a drive can be catastophic but usually isn't.
I suspect you may get lucky and find out it's just some of the circuitry in the trekstor shell that is damaged.
Take the Trekstor unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
1,916 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
