I have a WAG160N Linksys Access Point some times connections of my wi-fi devices find out problems and my wi-fi Device can not communicate with together. my devices are connected to Wireless Network but could not communicate with together until I reset WAG160N. Please help me.
  • 47 Answers
SOURCE: Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Posted on Sep 08, 2007
  • 83 Answers
SOURCE: WIRELESS NETWORK PROBLEM
u should buy a business class wireless router ie netgear perhaps
Posted on Oct 28, 2007
Alex1413
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Posted on Nov 05, 2007
ecmorgan69
  • 279 Answers
SOURCE: Wireless Connection failed
Did you make any hardware or software changes? You don't say.
Try seeing if your wireless radio is turned on. Most laptops have some kind of switch or Fn key combination that will turn off the wireless networking radio to save power. You might have inadvertently shut it off.
On the other hand, if it's a software thing and it only happened today, try using System Restore in Accessories --> System Tools and go back a day or two. If it's a software issue, that may resolve it.
Post back with any problems.
Posted on Dec 29, 2008
  • 104 Answers
SOURCE: Conecting my Brother Wireless Printer
Hello....I'll try and help you make a start.
1. To find the settings you need to set up your printer, you will need to login to your router. Open a web browser, as if to view a web page, but instead type http://192.168.1.1 into the address bar at the top.
2. If successful, you are prompted for a username and password. If you have not changed these, leave username blank , and enter password: admin. Otherwise, please enter the password you have set.
3. If you log in successfully, you should see the Linksys router configuration screen.
Select the Wireless tab, and go to ‘Basic Wireless Settings’ > Wireless network. You should see here your SSID or Wireless Network Name, as required for your printer setup.
4. Go to ‘Wireless Security’. If the ‘Security Mode’ is set to ‘Disabled’, your system is Open or unsecured: your encryption type will be ‘None’.
If, however, it is set to WEP, your WEP key should be shown below. If it is set to WPA-Personal or similar, your WPA Shared Key should be shown below. This is the key described in your posting as the WPA2-PSK or Pre-Shared Key: it is also known as the network key, security key, or passphrase.
I think this covers all the settings mentioned in your posting. For further information, SecureEasySetup, AOSS and WPS/Wi-fi Protected Setup are shortcut methods to enable security on your router. Recent versions of your router model support SecureEasySetup.
You can download a copy of the manual for your router from the Linksys site: http://www.linksysbycisco.com/US/en/support/WRT54G/download
(You will need to check your router label for the correct version number.)
I hope this helps. This advice is based on the Linksys WRT54G user manual. However, please come back to Fixya if this is not clear or does not work for you.
Posted on Jan 19, 2009
Having trouble with a wi fi connection from my cgo2 camera to my galaxy 7 phone.it will connect sometimes but not every time.anything i can do to get a reliable connection every time?
camera distance may be too far from wi fi source ie router or access point ? possible solution use a wi fi range extender.
Neighbours Wi Fi interfering with your WI FI . possible solution change the channel used by your wi fi from auto to channel 3 or channel 6 . This ensures channel spacing from neighbors if they are on auto as well . Setting in wi fi access point or wi fi router
Jun 12, 2018 | Galaxy Cell Phones
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
HELLO.I HAVE A SATELLITE INTERNET CONNECTION TOOWAY WITH MODEM RM 4100 VIA SAT.AND I WANT TO MAKE THIS WI-FI WITH ROUTER INTELLINET 524704.IT WORKS PERFECT BUT THE BIG PROBLEM IS THAT ONLY ONE DEVICE AT...
Your problem is with the 524704 device. This is NOT a router - it is a wireless access point. It is designed to be connected TO a DHCP router that can assign separate and unique IP addresses to each device that the Access point connects to. The way you are using this device will not work with more than one device since the unit is forced to use the fixed IP address from the wireless access point to the modem and only one device can use any specific IP address. You need to get a wireless ROUTER to achieve you goals.
Nov 03, 2013 | INTELLINET Computers & Internet
My laptop is connected to linksys modem router wirelessly, model number WAG160N. The problem is it keeps being disconnected after 5 to 10mins or worst its only a matter or seconds that it will connect then...
make sure that you have no electronic devices especially cordless phones near the route(including baby monitors, halogen lamps etc)r. if that doesn't help, try changing the wireless connection setup from wi-fi protected setup to manual setup and change the wireless channel to 11.
you can do this by connecting your laptop to the router via an Ethernet cable first and then log on to the GUI page using the internet explorer.(default is 192.168.1.1). if you need more instructions regarding how to do this, please reply to this post.
Apr 11, 2011 | Linksys WAG160N Wireless Router
How to work my ipad?
  • Turn on your iPod Touch or iPhone by pressing the top button. Wait for your iPod Touch to boot and slide your finger across the lock slider to unlock the device. You will now at the iPod Touch home screen
  • Press the Settings icon on the iPod Touch Home screen to change your system settings. Click on Wi-Fi near the top of the Settings menu. A list of available wireless access points will load.
  • Find your Linksys wireless access point from the wireless device list under the Wi-Fi menu. If you have already setup an security key for your Linksys router, you will be asked to enter the key after selecting it from the list. Press OK and wait as it connects to the router. Enjoy the added benefit of having your iPod connected to the Internet.
  • Oct 11, 2010 | Computers & Internet
    What is wi fi whats does it do
    Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
    A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
    In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
    Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
    Good luck and have a nice day.
    rating the solution is highly appreciated.
    Jul 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
    I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
    Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
    • Move closer to the Wi-Fi router or hotspot.
    • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
    • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
      • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
    After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
    • Check for any sources of potential interference.
    • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
    If you are unable to access the Internet while connected
    • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
    • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
    • Verify that the Wi-Fi network settings are correct:
      • Tap Settings > Wi-Fi.
    • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
    • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
    • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
    • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
    If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
    • Restart the device
      • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
    • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
    • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
    Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
    • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
    • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
    • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
    • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
    • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
    Mar 22, 2010 | Linksys Wireless-G WRT54G Router
    Cannot get ipod touch to connect to wireless network
    Many Wi-Fi issues can be resolved by doing the following:
    Basic troubleshooting
    • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
    • Verify that you are in range of your Wi-Fi router or base station.
    • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
    • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
    Jan 01, 2009 | Linksys Wireless-G WRT54G Router
    Open Questions:
    How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
    Aug 22, 2018 | Toshiba Computers & Internet
    Computers & Internet Logo
    218 people viewed this question
    Alun Cox
    David Payne
    David Payne
