Question about Timex 24101 Wrist Watch
Watch strap to long - Timex 24101 Wrist Watch
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
Need a new leather strap. Wheere to find?
I'm sure there's universal straps u can get but original strap keeps the value
Jun 14, 2012 | DG Dolce & Gabbana Cream DW0058 Watch for...
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
Jul 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Cerruti 1881 Watch
I need a replacement watch strap for my diesel DZ7100
Many stores such as Wal-Mart, Target, etc. sell replacement watch straps in their jewelry department. They may even replace it for you. Also many jewelers will have replacement straps and will install it for you. It looks like this watch has a very wide strap, so if you can't find exactly what you need, you may have to contact the watch manufacturer directly. Google Diesel watches.
Jan 13, 2011 | Diesel Strap DZ7100 WW Watch for Men
Nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
Feb 13, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
Where to buy a strap
you get watch straps on ebay or you can go to watch menders or market or jewlers have them
Oct 03, 2009 | Tissot Prs516 T91141731 Watch
Gossip watches with changeable ribbon straps
good day,
hope this link below will solve your problem.
watches
Jun 24, 2009 | gossip Rectangle Case Leather Strap Watch
Timex 24101 Wrist Watch Logo
49 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
