Question about Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM AIR CONDITIONER
How big does the room have to be to cool with this model
    Scholar:
  • 66 Answers
There are many things that need to be considered to properly answer this question. Number of windows, amount of insulation, direction the room faces and how high are the ceilings are just a few. Generally speaking (this is a guesstimate) you should be able to cool around 200 square feet.
Posted on Jul 11, 2010
Why is a brand new in wall ac not dehumidifying room
could be to small for room or could be to big for room. It the unit is too big it will cool the room down to fast and shut off to soon, this will not remove the humidity. Try running the unit on a lower temperature the slower the fan the colder the coil which will remove more humidity from room also make sure the fresh air vent is closed and not bringing humidity from out side.
Jun 11, 2014 | Friedrich Heating & Cooling
Related to cooling
Sounds like you have poor insulation in that room or the unit is undersized for the room it is cooling. It should not get hot quickly is there is good insulation and is big enough to do the job. Since you do not mention the age of your home/room or the size of the room, I can't be more specific. The number of turns may or may not be an issue. Depends of which of the lines are taking all the turns. Are the lines insulated? If they are overly long this could take longer to cool down but not much else if the system in full of Freon. If you do not feel cold air coming out of the unit at all and the compressor is running then check the air filter. If it is the littlest bit dirty and the unit is undersized for the room then any restriction would make it even more ineffective.
Apr 20, 2014 | LG LSC121PMA Split System Air Conditioner
The conpressor runs allthe time
Do you have the Tstat set to low? are you trying to cool to big of a room? Is it relly blowing out cold air? You might want to shut it down for an hour or so and let it deice. Or it low on charge? have you serviced the filter latley ? My bet is the filter is dirty. and you cooling to big a room and its iced up so shut it down and see if after anout one or two hours you trun it back ona dn get more air flow.. close off unused rooms and place floor fans a round
Jul 13, 2011 | Maytag Heating & Cooling
NEED TO KNOW HOW BIG AN AREA A 10,000BTU SWAMP COOLER WILL COOL.
That will cool a normal size room. The cooling capacity depends on a lot of things like how well insulated the room is.
Jul 20, 2010 | Mastercool Portable Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Warm air
How big of a room are you trying to cool? The rule of thumb is 600 sq ft per 12,000 btu.
Aug 21, 2009 | Sunbeam Heating & Cooling
My LWHD1200FR AC Unit is not cooling during the
The unit may not be big enough. From the model number I am thinking you a/c is a 12000 btu. Which is usally enough for a large room. However if you have an open floor plan or a really large room you may need a bigger or second unit.
Jul 05, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
My room is not getting cool. the air conditioner is brand new, out of the box, perfectly clean
It sounds like your air conditioner isn't big enough to cool the room you have it in. SInce it is brand new return it and get a larger one. Tell the store clerk the dimensions of your room and err on the side of bigger as opposed to smaller that the dimensions call for.
Jun 26, 2009 | Heating & Cooling
Hot Upstairs
A good heating guy should be able to balance your dampers to increase the airflow upstairs. Keep in mind heat rises. 2nd floors are the hardest to cool. You may need to add more returns to pull the heat down the the evaporator so it can be cooled. If you are lucky you may be able to adjust your blower up to a higher speed. You may have to even add some more supply airs. Check with your local building inspector. He may be able to give you a list of contractors in your area that would be good for this type of problem. Good luck>>>
Apr 02, 2009 | DeLonghi Pinguino PACL90 Portable Air...
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Donni Steen
Colin Stickland
Colin Stickland
John Tripp
John Tripp
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
