Question about Franklin Chef FT386 Refrigerator With Ice Box
The freezer fills up with ice completely - Franklin Chef FT386 Refrigerator With Ice Box
    President:
  • 2,702 Answers
The thermostat is likley to be faulty and is stuck full on,,,or the door is letting in hot wet air,,,,this will freez up,,,
Posted on Jul 10, 2010
Long time not using the ice maker, today I tried an is making ice
I would replace the water filter first off. If you have completed that already then I would check the water fill outlet for calcium build up. If that is clear, check to make sure the solenoid is energizing for the fill. If you have water to the basin and it is still not working I would have to check the timer to see if it is initiating a cycle for the ice.
Apr 08, 2014 | KitchenAid 18.5 cu. ft. Bottom Freezer...
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
How long after hooking up ice maker does it take for the water to start running in. we have water in the door water just not in the ice maker?
Should have started to fill soon after freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice approximately every three hours. The above was in the user manual and only answers when the process begins. There is a thermostat embedded inside the ice maker that tells the water control valve for ice maker to open for approx. 7.5 seconds. Because this model has a freezer below the left fresh food section light switch has an interlock that completes 120VAC to the ice maker once the fresh food section door is closed. Defective fuse, door switch or ice maker will make operation impossible until the problem is located. Please let me know if you need assistance beyond the above here.sea_breeze_27.jpg
Thanks, Sea Breeze
Dec 16, 2010 | Amana ASD2620H Side by Side Refrigerator
I have a Whirlpool refrigerator with the ice maker inside the freezer. It does make ice, but a lot of the ice bubes are either hollow or partly formed. I took the filter off completely and it not help. Any...
Good day,
Sounds like your not getting enough water on the fill cycle.
Unlike a washing machine, you have 7 seconds for a fill cycle to complete. Period.
It's either the water valve on the bottom rear of the machine not opening completely and must be replaced since it's a non-repairable item, or the house water supply system is corroding and slowing the water down.
Sep 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking water from freezer, have no clog in drain. Ice and water fall down back of inside freezer!! Water on floor a lot?
Good day,
Sounds as if the fill tube to the ice maker is either plugged with ice, broken, or adjusted improperly.
Remove the ice maker, then the fill tube needs to be inspected closely for the issues above.
As well, the fill valve in the bottom rear of the machine might not be shutting off completely after filling the ice maker well. If that is the case, the valve is non serviceable and must be replaced.
May 30, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer does not freeze some items completely and ice maker not
Replace the defrost timer. Take your make and model number to appliance part store and get a defrost timer. Relatively cheap and usually easy to change...
Jan 04, 2009 | Amana Refrigerators
IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Aug 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Franklin Chef FT386 Refrigerator With Ice Box Logo
76 people viewed this question
Top Franklin Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Refrigerator Expert? Answer questions, earn points and help others
