Question about Broan-NuTone Solitaire S90 Fan
What fan can replace the Broan S90-A? It fits 9 by 9.5" ceiling cut.
  • 72 Answers
SOURCE: have a broan n688 ceiling exhaust fan in bathroom
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Posted on Oct 07, 2009
SOURCE: QT 100L replacement
Forget it. I also had the same problem with the QT100L. Cannot buy this unit and the replacement unit is the LS100L by Nutone/Broan. Good news: it is more powerful 110CFM and the housing is the same size. Bad news, the motor assy is completely different and it cannot be mounted in the existing housing. To install the new unit, you will need to cut the ceiling around the fan housing and install the new housing and wire it as well. Be aware that the wiring comes into the housing 180 degrees from the old QT100L unit. That means I hope you have enough romex to reach the hole. My advice is to get another unit from any other company because the quality sucks. It will be as much work to install any other brand as the LS100L.
Julius in CT
Posted on Nov 25, 2007
  • 37 Answers
SOURCE: bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Posted on Jan 31, 2009
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Posted on Aug 01, 2010
  • 95 Answers
SOURCE: We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Posted on Nov 19, 2010
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
CAN NOT REMOVE HOUSING FROM CEILING
If you take light lens off and bulb out you should see a wing nut or nut take it out and the whole trim pc will come off . You may have to cut around trim to cut it loose from paint .
Jan 24, 2012 | Broan-NuTone 679FL Combination Light Fan...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Feb 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
How to remove and replace Nutone 669FR bath fan
The easiest solution is to replace only the motor not the whole fan. If you want to replace the whole fan you might be required to cut the housing out of the ceiling.
Feb 22, 2009 | Broan-NuTone (668RP) Fan
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Broan-NuTone Solitaire S90 Fan Logo
2,856 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
