Question about Cooper Industries Cooper Wiring 274W Switch and Outlet
Trying to install a Combo Switch # T5225 Leviton. I got a red , black and orange (no t used)
jse2005
  • 103 Answers
SOURCE: I am trying to replace a two wire light
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Posted on Jun 28, 2010
VtToolMan
  • 704 Answers
SOURCE: I am replacing a combination 2 switch using a
First, turn off the power to this circuit to avoid getting a shock.
If the two devices that are controlled by the combination switch are lights, you will want to join the two (2) white (neutral) wires together with a wire nut, as these are not connected to the switch.
You also want to connect the bare copper wires (ground) together and connect one of them to the switch's green grounding screw and IF the wall box is metal, you also need to attach the ground wire to the box with a green grounding screw.
Now, you can connect the wires that go to your lights, the red and black wires that are part of the same wire and are routed to the same location thru the wall box. Take either the black or red and connect them to the screws on the side of switch that are not connected together with the small brass strip between them. Put the red on one of these screws and the black on the other.
Now with the black wire that is the hot (Common), this is the one that is bringing power into the wall box, should be connected to the other side of the switch, the one with the two (2) screws that are joined together with the brass strip between them.
This will allow you to turn on and off each of the lights (or a fan, etc) separately with each switch sharing the common power source.
Here's a picture of the switch that shows the side of the switch with the common side and the brass strip that connects the screws together. This is the side where the one black (hot / common) wire that supplies the power gets connected.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8935&section=10070
You can also open up the box the switch came in and you'll find a wiring diagram for the switch that illustrates how to properly wire the switch for your application.
I hope you find this Very Helpful and best regards!
Posted on Oct 10, 2009
  • 16485 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
  • 3 Answers
SOURCE: not sure how to wire this switch
Switch will have a commom terminal that the hot wire connects to.
The other three terminals are for the devices -- light, fan and other device.
The white wires should be the grounded wire returns for the circuits unless they are identified by color tape to be hot line side of power.
Be careful of the grounded side of circuit, can shock or kill, treat all wires as being energised. If you are not sure, use a electrical tester,
or get help.
Posted on Jul 22, 2010
SOURCE: We are trying to install
You are installing a combo device with switch and outlet.
The outlet is tamper resistant so a child cannot stick a key into outlet and get shocked.
For the outlet to work, a 2-prong plug must be inserted.
Wiring the device:
Electricians don't guess, they test.
Device has different colored screws: dark, silver and brass.
Separate wires for testing.
Do not unwind wires that are twisted together.
White wires that are twisted together and located in back of box are included in testing.
Use ordinary 2-lead tester.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire connects to dark screw.
Hot is identified.
Test Hot wire to all other wires, except bare ground wire.
Tester lights up on Neutral wire. Neutral connects to silver screw.
If you do not have a Neutral wire, then outlet will not work for that location.
You can get the outlet to work by connecting bare ground to silver screw, but that is violation of code.
Last wire goes to Load (light, fan, motor).
Load wire connects to brass screw.
In your case, this is red wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 19, 2011
I'm trying to replace a switch outlet combo with a leviton pr180 with occupancy sensor...it has black, red, green, and yellow red wires. The wiring in the wall is one black and white and ground for the...
In addition to the black, red, green, and yellow/red wires on the switch, there should also be a white wire or terminal marked WH. The black wire on the switch connects to the incoming black wire (line in or hot) inside the switch box. The red wire on the switch connects to the outgoing black wire (to the load) inside the switch box. The green connects to the bare wires inside the switch box. The yellow/red is not used in a single pole application such as yours. The two white wires inside the switch box are twisted together and _also_ connected to the WH terminal (or white wire) on the switch.
Jun 29, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
I have a standard light switch that controls one overhead light - fine. Now I want to replace it with a Leviton T5225 which I think is the right weapon for the job -- one unit that has a light switch and...
It sounds like you have power in your light, power is fed down on the white wire and the black wire is switched and connects back up to the light. You do not have a "neutral" in the box, so you cannot run an outlet with the wire that is currently available.
Feb 27, 2011 | Leviton 8299 Combination Switch / Smart...
Trying to install this thing, and having a slight issue. I've got a white, black and red line power line in the bathroom, obviously.. I've also got a dual switch Leviton 5634 which I'm just trying to...
I assume these three wires are coming to the switch box via from the light/fan unit and the light/fan unit has a box with 5 wires in it, including a white and black from the electric panel, and that the neutral is not routed to your switch box. I think your mistake is assuming that the black wire in the switch box is the hot wire, but it is actually the red or the white. Try switching the wires on your switch so that the red is common, If that doesn't work, try the white as common. Or you might open the box where the fan is, and confirm which of your three wires is connected to the hot black wire. Please vote if you found this helpful.
Good luck, Al K
Feb 24, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
Trying to install a combo leviton switch that has two back wires on it. my outlet has two back two white and one red wire, where does the two black wire go?
Question is not clear.
What kind of device is the combo device replacing?
Are you replacing outlet with new combo device?
Why does the combo device already have 2 black wires?
Here's what we need to know to answer your question correctly without guessing.
Add a comment and say what kind of device is being replaced with combo device.
Say exactly what wires are on old device and what color screw wire is connected to.
Say what the outlet is doing.
Say what color screws that each wire is connected to on outlet.
Screw color is key to understanding where you are.
Each wire that you have now connects to a certain screw color, and we need to know that information to give you professional answer.
Feb 01, 2011 | Cooper Industries Cooper Wiring 274W...
We are trying to install a Leviton No. T5225 Combination switch and tamper resistant outlet. We are replacing the single light switch with this new one. We have a red, a white, and a black wire. When we...
Wiring the device:
Turn power ON.
Hot is identified.
Jan 19, 2011 | Leviton 8299 Combination Switch / Smart...
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Sep 02, 2009 | Leviton Decora Combination Switch - 5625-I...
Cooper Industries Cooper Wiring 274W Switch and Outlet Logo
963 people viewed this question
Top Cooper Industries Electrical Supplies Experts
john h
AJMAL KHAN
Gene Haynes
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
