Question about Toro Garden
Toro riding mower steering linkage(one side with small ball/socket) popped apart. Can I fix it?
  • 420 Answers
Those are not fixable, they are inexpensive and should be lubed each year. go buy a new one for both sides but pay attention to how many threads to spin the new ones in or you will throw off the front steering alignment.
Posted on Jul 16, 2010
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Death wobble in 4x4 van
Check you steering and duspension system. Check ball joints and steering linkages. With the vehicle in the floor have someone move the steering wheel side to side. Not whole turns just side to side movement while you look at the steering linkage to identify any loose parts. Then raise the vehicle and check your ball joints by grabbing top and bottom of the tires and shaking them.
Nov 13, 2012 | Cars & Trucks
Toro wheelhorse riding mower 1638hxl very slow forward gear
if it works fine in reverse adjust the linkage rod on the pedal
Jun 08, 2012 | Toro Garden
1994 chevy k2500 aligned,new tires, new shocks and it still wanders when driven sraight
The most likely cause is a worn ball and socket (not the 'ball joint' on the suspension) on the Pitman arm for the steering linkage. The steering idler arm's ball and socket may also be worn. The parts are cheap, but it is a PITA to remove the Pitman arm. This can be checked by seeing how much steering wheel play you have before the wheels do anything. Looking at the Pitman arm while doing this may scare you. I drove with a bad one for ~1 year, and was always scared the ball was going to pop out of the socket and result in no steering.
Mar 03, 2012 | Chevrolet 2500 Cars & Trucks
I have a Cub Cadet LT1050 that's 3 years old and the steering just went out on it. The two gears that mesh are no longer 'meshing'. Cant tell if there's a bearing out or what, aparently without taking the...
-same problem, relatively easy fix. As you look at the 2 meshing gears, you will see the center gear (at the end of the steering shaft) has a nut on it. Remove that nut using an 11/16" socket wrench and pull the gear straight down (don't loose the washer). Now raise the steering column straight up from the top. From underneath, use your finger to pop the worn "bearing" (it's really a bushing) up from it's holder. You will need to fish it out from the upper side. Replace this "bearing"--Cub Cadet # 941-0656A [replaces 741-0656A]
Bearing, Hex Flange, 5/8. Reassemble in reverse order. Hope this helps.
May 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Sears craftsman lawnmower has steering linkage poping out of socket
It should have a keeper on the top or your linkage is bent, how does it compair to the other side or is this the linkage under the steering wheel?
Oct 22, 2009 | Craftsman Garden
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
448 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
