Question about Maytag Dryers
My dryer is about 20 years old and has never given any trouble. About a month ago I noticed it started taking longer to dry a load. Now it barely heats at all. Do I need a new one or is it worth fixing?? Is it a heating element and about how much is it to repair?? Jeanne
  • jeanne_gay Jul 10, 2010
    I couldn't find a white housing in the back cover panel so I cleaned out the exhaust tubing which was clogged with lent and paper. I will have my brother check further when he is available, Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things: Mainly Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. A new thermal fuse will cost you around $21. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
Hotpoint aquarius ctd00
The noise could be .... the drum sometimes has stick on metal pads for balance or heat shields that will come up and start smacking on the cabinet of the dryer. Remove or lift the top of the dryer and turn the drum and looks for these pads. if one has lifted either glue it back or cut the part off that has lifted.
As far as the not drying part ..... it could be that the dryer is just getting tired and the heating element is gong bad or it could be something as simple as cleaning out the vent going out of the house. You can do this by disconnecting the dryer from the wall and blowing it out with a leaf blower or having someone come in and do it professionally.
Hope this helps.
Nov 25, 2013 | Washing Machines
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
No heating
Greetings,
The heating elements do not cost $200 USD buy $80 for both; available online from the most common Fisher-Paykel parts supplier.
Good luck
Apr 13, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
Really loud noise when my dryer is running now. It seems to be taking longer to dry a load since the problem began but still dry's none the less. It is an Inglis Superb Plus that is at least 20 years old....
First thing check if the lint trap and the exhaust hose are clogged. Make sure there are no sags or kinks in the hose and that it is a short direct run to the vent. That could be the cause of the slower drying as the machine has to work harder. The noise could be a bearing and that is also the result of excessive work. As the heater coils get old the metal begins to sag from the constant heating and dries clothes slower and they eventually snap and fail. At twenty I would consider a new energy efficient model rather then a repair. Insiders will tell you that most washer dryers a built to last only about five years. Newer models can be very energy efficient compared to those built twenty years ago. Find out what the energy consumption is on the new model. What you pay for the new machine will be offset by the money you will save on your power bill.
Jan 08, 2010 | Dryers
Stopped running. Can't start.
You probably have a clogged vent. If the moist air can't vent to outside your dry times would be much longer and the heat would get trapped in the dryer. This probably caused your thermal fuse to fail. Once that fails the dryer won't do anything. The good news is that it should be a fairly inexpensive repair.
Dec 09, 2009 | Dryers
GEW9200LWO takes longer to dry clothes than it use to. checked according to to use guide trouble shooting. dryer is 8 years old and runs fine other wise.
Check your lint vent hose and the vent to the outside part is clogged. If any lint is built up it will restrict the air flow hence longer time to dry.
Oct 17, 2009 | Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not drying clothes anymore!!
Get the power company to send a repairman out there. The power surge mess up the controls.
Apr 09, 2009 | Whirlpool ET8CHEXSQ Dryer
Several problems ... now no power at all!
Hi. thanks for the question . You started to have the motor problem when it would shut down . wait a while then go again .the growl you hear now. is that the motor is now shot .you need a new motor. thanks the appliance doc
Sep 30, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
Dryers Logo
22 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
