Question about Mastercool Portable Air Conditioner
The mastercool P500A is not cooling just blowing warm air and the cool button is lit up? Is this normal or should I check something else on the unit?
  • Mastercool Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Mastercooler blows air for about 5-10 mins and than shuts off. Then turns back on a few minutes later. What's wrong with it?
It could be overheating, resulting in thermal shutdown. After the unit cools, blowing resumes.
May 09, 2018 | Heating & Cooling
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
Heater not blowing hot air
when you operates the heater button worm water of your engine's water jackets enter to the evaporator locates inside your A/C blower & air flows through it & air becoming worm. Therefore I proposed you to check your vent linkages for vent doors inside the blower unit.
Nov 24, 2013 | Land Rover Range Rover Cars & Trucks
I need a manual for my mastercool P500A
http://www.retrevo.com/support/Adobeair-P500A-Air-Conditioners-manual/id/20613ag015/t/2/
Click on the download document 2.02mb .. not the big download bottom on the right .
Good luck any detailed problem you have or just want the manual?
Feb 02, 2012 | Mastercool Heating & Cooling
Just started making an odd noise. Normally compressor blows out warm air. Air being blown out now is very cool
Unless I'm missing something in what you said, air conditioners are supposed to blow out cool air, rather than warm air. Or does the air just feel cooler than what you had the thermostat or comfort control set on? If that's the case, turn the comfort control or thermostat Up a bit.
I hope this helps. Thanks for choosing FixYa.
Jul 26, 2011 | Carrier Heating & Cooling
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Mastercool  Portable Air Conditioner Logo
472 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
