Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
  • 53 Answers
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Posted on Jul 11, 2010
Automatic transmission does not work
Is the little wire looking lever pushed in at the rear of the tractor.
Is the belt tight and on the pulleys.
Nov 11, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor will not move with engine running Craftsman 917.287070
Make sure your drive belt, the topmost one, is in place and snug on the pulleys. Do not do this while the engine is running! If the engine is running fine and the belt is transferring power, then the problem lies with your transmission. You can find these used at mower bone yards and on ebay.
As most of these lawn tractors are made by just a few companies, you will find the same transmission is in many different mowers.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Drives fine on level terrain start up a slight grade it stops,engage brakes nothing tractor goes backwards will not stop.
When you go up a grade do you smell the belt burning (rubber burning smell) when it starts going backwards on you. It could be that the drive belt is not tight enough.
May 05, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor runs fine but will not go up a incline and belt is tight
from the description, i would guess that the brake is stuck and dragging. if it is a hydro, it could also be that the bypass lever is not fully releasing
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftsman model # 917.274031 garden tractor.
check the rear wheels,has you fixed a flat and not put a key back in or not fitted the wheel correctly.
Some hydro ?? cut out levers only have a spring to pull it back and get stuck.
Dec 08, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
339 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
