Question about Amana RanARG7302 Gas Kitchen Range
The oven sometimes does not work when turned on, but sometimes turns on after a period of time. Also, sometimes there is a strong smell of natural gas, but other times not. It appears that the ignitor is going on, but perhaps it isn't hot enough to start the burners. Is the problem the ignitor, gas valve, or something else? The range is an Amana model ARG7303WW.
  • Jerry Goggins Jul 14, 2010
    Your technician's analysis was correct...the problem was the ignitor, which I successfully replaced. The oven works great. Thanks for your thoughtful suggestions.
  • 10,515 Answers
This is a common problem with these models. This is highly suggestive of ' Faulty Ignitor '.Its a common problem with all gas stoves the ignitor wont get hot enough to burn off all the gas coming from the safety valve.it does glow but not the white hot it should.
Its the ignition system they use now instead of a constant pilot.
And if not replaced it will get worse.
Here is more info for you on the problem.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter :-
http://www.applianceaid.com/electrical_testing_tips.html
Compare it to this repair sheet before you can say it's OK or not :-
http://www.applianceaid.com/images/hot-surface-ignsheet.jpg
The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the ignitor gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface ignitor will not come on - check ignitor with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new ignitor time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface ignitor problem. The hot surface ignitor often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface ignitor. The hot surface ignitor can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the ignitor. See this service sheet for the proper way and amp readings for the hot surface ignitor system :-
Hot surface ignitors do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar ignitor can glow orange-red and still be bad!! How a common gas valve works :-
http://www.applianceaid.com/how-bake-valve-works-C21.pdf
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
OK we just converted a brand new natural gas kenmore range to propane and followed the instructions to a tee doing it. The burners are fine and work great, no smell. When the oven is started it smells like...
There is a conversion in the regulator that must be done or the oven flame will not be correct. Usually it is just removing the regulator cap, turning the converter around and putting the cap back on. This may be your problem.
Oct 01, 2014 | Kitchen Ranges
I just turned on our pilotless oven and noticed the smell of gas. Turned it off naturally. The stove worked fine earlier in the day.
You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps.
Good Luck
Jul 31, 2014 | Maytag CWG3100A Gas Single Oven
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
My Kenmore gas oven sporadically takes forever (30+ min. to heat up to 350 degrees). Sometimes it works fine, & other times it takes at least 1/2 an hour. Also, I periodically smell natural gas when I...
Sounds like a weak ignitor. If it doesn't get hot enough to allow the proper amperage through to the gas valve, you will have this symptom.
Jul 25, 2009 | Kitchen Ranges
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Amana RanARG7302 Gas Kitchen Range Logo
176 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
