Question about Friedrich QuietMaster KS15L10 Thru-Wall/Window Air Conditioner
KS15L10-E compressor trying to start with high-pitched squeal then failing but starting just fine about 30 seconds later? This is 3rd compressor with this problem. One note: If I allow the fan to turn off between compressor cycles, the compressor stays off for about 3.5 minutes then turns on fine. If I keep the fan running between compressor cycles, the compressor only stays down for about 1.5 minutes and tries to restart with a high-pitched squeal then fails. It will restart itself with no problems about 30 seconds later. I have been able to repeat the above process numerous times. The problem is that I need the fan to run between cycles.
  • 96 Answers
SOURCE: fans wont turn without manual start
You have a bad start capasitor
Posted on Dec 12, 2008
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
  • 588 Answers
SOURCE: friedrich quietmaster fan does not come on and
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Posted on Aug 25, 2009
heatman101
  • 43501 Answers
SOURCE: Compressor failure, sends out hot air
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
  • 767 Answers
SOURCE: Describe your KS15L10 Thru-Wall/Window Air
Hello my name is Heath iot will be my pleasure to assist you. The first thing to do is unpludd the unit then go out side wioth a garden house and use a strong jet of water and blow it through the coil and get it real clean if you can then try running the unit.
Posted on Aug 29, 2011
Bendix engages followed by high pitched squeal
Pull the stater and check the teeth on the geat and also check the flywheel teeth, it sounds like the starts is not engaging the teeth of the flywheel.
Mar 20, 2014 | 2006 Ford F-150
High pitched squeal when defroster is on
sounds like your ac compressor is failing, fix it before your belt breaks and leaves you stranded.
Feb 13, 2018 | 1998 Jeep Grand Cherokee
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
High pitched squeal when starting car
Sounds like a belt, and possibly the one on the power steering pump which may be the sepentine belt. Could be caused by power steering pump pulley resistance or the belt tensioner bearing. Try a visual check with motor running. Be careful of moving parts!
Jun 06, 2012 | Charging & Starting Systems for Lexus...
Breaks have a high pitch squeal when i break ata any speed. got breaks checked out and mechanic saidneverything was fine
A high pitch squeal is typically normal. However I have NEVER liked it.
I would replace your brakes with a higher quality brake pad, and see if you still have the problem.
Your pads can squeal when they are getting low, i would also get a second opinion on the condition of the pads.
Jul 16, 2011 | 2006 Chevrolet Aveo
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
Friedrich QuietMaster KS15L10 Thru-Wall/Window Air Conditioner Logo
53 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
