Tannoy Saturn s10 Dual concentric problem
Hi
an accident happened while I pull up the driver. the magnet (has a sticky material at the bottom of it) so it`s drag up the diaphragm while pulling up the driver from the box.
I assembled everything back, but, the Dual concentric not working as expected.
do i need to get a new one? is there any way to fix it?
best regards
Vick
    Novelist:
  • 169 Answers
Tannoy dc speakers are built to very high tolerances. they are very easy to damage if taken apart so i suggest you contact a specialist tannoy service shop.
i know a shop in london who sells a lot of
vintage tannoy speakers and he says very few repair shops are capable of fixing these dc drivers. good luck
Posted on Apr 23, 2008
My TV has a milky screen
If that's default problem since u have bought it, u should repair or change another New one.
If it happened for an accident no solutions without repairing. I think u kept magnetic materials beside your TV. Thanks
Feb 02, 2015 | Miscellaneous
How many speakers can you connect to a tannoy s10
The question doesn't really make sense because a Tannoy S10 is a speaker. You can daisy chain as many speakers as you want. That's not the issue though. It's what load the amp sees that's the problem.
Most Hi-Fi speakers are a nominal (that means average) 6~8 Ohm load. However, the Impedance varies with frequency and phase. So at certain frequencies the amp will see a much higher load; maybe as much as 30 Ohms. At other points the load will drop to 3 or 4 ohms. The reason why your amp doesn't fry itself is that music contains a wide range of frequencies, so the load is made up of lots of different slices of impedance all summed together.
If you start to add extra speakers on to an amp then one of two things will happen. Either they'll be wired in series; in which case the Ohms load will increase by the addition of the speaker impedances e.g. 8 Ohm + 8 Ohm = 16 Ohms pre channel. Or the impedance will be reduced because the speakers are wired in parallel (1/8 + 1/8)inverse = 4 Ohms.
16 Ohms is about on the limit of what a very good Hi-Fi amp could drive. But the volume will be reduced and the amp will go into distortion much earlier.
4 Ohms is a much bigger problem. The impedance swings will dip dangerously low to the point where the amp sees the speaker load as a short across the terminals. At that point the amp will dump a whole load of current into the speakers, thus frying the voice coils and burning itself out. That ends with a small puff of smoke and a very large repair bill.
If you want a system louder then you have to add more amps and more speakers. Simply piling speakers on to an existing amp won't do it. You're spreading the amplifier power more thinly because of the extra load, so each speaker ends up being quieter.
Aug 29, 2014 | Audio Players & Recorders
Paper jam 2 scx 4200Hello, my Samsung scx-4200 had a paper feed problem.When i try to print 1 page of something, the printer takes 1 paper, and then continues to take paper after the first and then there...
Try this, inside the printer, normally when you open the case/ink port, you see all the paper feeding gears and rollers. You really don't have to be a tech for this, just make sure there are not any flakes/small pieces of paper inside. This is when its good to have a can of compressed air, available at many electronic stores, and "blow" out the dust/paper. This helped with my printer. Also, make sure all the paper feed areas are lined up and working. Watch how far the paper feeds into the printer, then look what is at that point in the printer. Best Wishes, CD
Nov 20, 2013 | Samsung SCX-4200 Series
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
How do I replace a fuse in the Tannoy TS10 Subwoofer
The fuse is located under the AC input cable. Pull out the cable and you'll see there is a slot that will fitt a flat screwdriver. Pull this out and you'll find the fuse.
Jul 21, 2012 | Tannoy Fusion TS10 Speaker
Little fingers have made an impresion in (or should I say flattened) my tweeter foil. Is there an easy way to replace this or fix it? Waiting for an answer as I only just got it for a completion to my...
hi!
try to use some really sticky tape, press gently to foil and pull out. retry until you got the best result but do not expect it will be like new it was before, effectively it is a nice feature, your speaker is modded by kid... :)
kind regards
Feb 11, 2011 | Tannoy Sensys DCC Center Speaker
Tannoy saturn s8 speaker had with me for 5yrs,how long do you think that it will last even though I well take care of them
If you take care of your speakers, it may give you good service for another 8 to 10 years. The working of a speaker depends on the condition of diaphragm and voice coil of the speaker.
If speaker is not overdriven(given more audio level than its power rating), kept free from moisture and diaphragm is prevented from damage, then speaker will work for 10-15 (even more) year with out any trouble.
Thanks for using Fixya.
Rating answer will encourage me.
Oct 21, 2010 | Tannoy Saturn S8 Speaker
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
936 people viewed this question
 Grubhead
Grubhead
