Question about HP Pavilion zd7000 Notebook
Need to repair the power jack. I am an electronics engineer with all the necessary equipment and expertise to repair my zd7000 if I can just get the thing disassembled without damaging something.
    Top Expert:
  • HP Master
  • 28,352 Answers
Check out dissasembly video on utube.
Posted on Nov 24, 2013
HP ZD 7000 wont power up. Will plug in, power light on, press the power button, light goes out computer doesnt turn on
I had a similar though somewhat different problem. My zd7000 was plugged in but it was oscillating between charging the battery and running from the battery. In the past I'd adjust the jack position and life was good - this time nothing mattered. I turned the laptop off and noticed that the charge light came on and stayed on - I guessed something was freaky with the battery so I switched to my spare - the charger light came on, I turned on the power I had a brief power on followed by zzzzttt then everything died. I could smell the stench of electrical burning. I disassemble the whole laptop and removed the motherboard - the back of the power jack is burned. A new jack is $10.
If I had to guess, I"d guess you have a bad jack. I've seen offers to repair this on the net for $100. If the offer is legit, I'd rather pay the bucks - theres only 5 billion screws in the laptop - plus the risk of static discharge damaging to boards or the pain of getting the processor heat sink out without damaging the processor and then getting heat conducting "grease" between the processor and the heat sink when you put it all back together again. I figured my unit was dead anyway, might as well see if I could find the issue. Now I need to get a new jack - and see if I can get it all back together again...
Dec 13, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
I need instructions on how to remove engine from start to finish in the easiest possible way or a manual on how to remove
better get yourself a manual, and find a shop to do it in, as well as an assortment of jacks, trans jack, engine jack. actually a lot of equipment, and a few days, mark where everything goes, including bolts and brackets, and pay special attention to electronics
Nov 17, 2010 | 1998 Chevrolet Blazer
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Aug 05, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hello I have a dell Latitude D610 laptop, The system works great running off the batter. The dc jack was broken, so I de-soldered the broken jack, and noticied a a couple of scratches on the board by the...
Yes, you should be concerned.
First of all ... the etched electrical traces on motherboards, or any other electronic circuit board for that matter, are very thin.
You need to make sure you are using a soldering iron which allows you to regulate the temperature of the tip of the soldering iron.
If your iron is too hot, the pads will definitely be lifted from the board.
Secondly, the scratch you can visibly see with your naked eye could "potemtially" be deep enough to cut entirely through the trace on the board.
I'm not implying this is the case in your scenario, however, you need to consider the possibility.
When it comes to repairs of this nature, "skilled" techs have gone thorough a "micro minature" repair couse in which the individual learns the proper processes and procedures necessary to make the types of repairs you are describing.
During these classes, the use of a microscope coupled with a steady hand, is absolutely necessary.
In your particular case, I would attempt to resolder the connection and hope for the best, especially if you don't have the proper equipment to effect the repair.
If you attempt the repair only to find out you still have the same problem, all is not lost. You may find that you do in fact have a broken trace.
You can circumvent this problem by utilizing a wire soldered between points A and B.
In summary.... try to resolder the jack first. With luck... you will be done at this point.
If not..... you will definitely need to examine the board to find out if any of the traces have been severed.
If you need any other assistance..... don't hesitate to ask.
Good Luck!!
Dec 03, 2009 | Dell (002TR) Motherboard
My hp zd7000 mobo has a short circuit,and won't power up,can you tell me which electronic parts to chech for to solve my problem
If the computer won't start--that is, if you push the on/off switch and nothing happens, then you should replace your power supply.
I doubt very seriously there is a short circuit.
Oct 30, 2009 | HP Pavilion zd7000 Notebook
Is HP Pavilion zd7000 screen compatible with HP Pavilion dv8000
Probably, but it would likely require hard wiring the two together. Unless you're a seasoned electronics tech or laptop repair tech, you should probably not bother.
Sep 26, 2009 | HP Pavilion zd7000 Notebook
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
How to make radar electronically
This is not something to try unless you have a ton of engineering expertise, and hundreds of thousands of dollars for test equipment. High frequency RF signals are some of the most challenging electrical engineering problems that exist.
Jun 07, 2009 | EarlyWarning Vehicle Parts & Accessories
The small yellow plasticpeice that cord connects to has fallen in
if you need a power port or someone to repair it for you, i can help you.
Apr 13, 2009 | Magellan Maestro 4040 GPS Receiver
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
