Question about Aiwa AV-D30 Receiver
AIWA AV-D35 volume max's at turn of knob, resets to 20 when power turned back on.
4 Suggested Answers
SOURCE: AV-DV75 volume control not working
i have seen a lot of people with this problem on this receiver... it is really bad quality i guess :(
Sorry can't help.
Posted on Jan 14, 2008
SOURCE: volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Posted on Jun 02, 2009
SOURCE: AIWA AV-D58 receiver ECO problem
Hi, I've found the problem. There was a closure in the Sorround Amlifier, and the protect circuit stopped the whole receiver. Br., csdombi
Posted on Jan 07, 2010
My volume doesn't change
MORE THE LIKELY THE SENSOR WENT OUT IN THE KNOB.
Jun 17, 2009 | Aiwa CDC-Z127 CD Player
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Aiwa Shelf system volume control doesn't work right
The part in question is called an encoder. I have had to replace this part on a number of Aiwa units. If you can post the model number off of the back, I''ll get you the part number.
Dan
Oct 01, 2008 | Audio Players & Recorders
Hi Deebo check the following website www.dalsani.com www.repairworld.com good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
Apr 25, 2007 | Aiwa AV-DV75
In Aiwa AV-D58 5.1 can't turn on [ it only ECO ]
when turning it on hold the enter key at the same time to reset the machine back to the factory settings
Oct 30, 2006 | Aiwa AV-D58 Receiver
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Subwoofer output
There could be a number of reasons causing this malfunction, try replacing the subwoofer's cord, it might be damaged, you can also try reseting the system to the factory settings according to the following instructions: Reset Instructions: 1. Press the power button to turn off the power 2. Press the power button while pressing the ENTER button. (note: this will reset all memory) Good Luck
Jan 09, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-D30 Receiver Logo
325 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
