Question about Element Electronics FLX2211B 22 in. LCD TV
How do you remove the stand off the element television?
Element tv modelFLX18511B broken stand
Go to the Element support website:
http://www.elementelectronics.com/support
Another possibility is to check eBay.
Apr 13, 2014 | Element Televison & Video
UNDO ELEMENT TV STAND
Safely face down on padded surface with no weight on screen---locate up to 4 machine bolts that anchor the base stand to the set and remove.
Nov 06, 2012 | Televison & Video
I have an Element TV, model #FLW-1921B. I installed the stand that came with the TV, but now I want to mount it on the wall. How do I get the stand off? I tried, without any luck.
Hello, are there no screws under the stand itself that you can access? You may have to tip the tv on its head to get at them.
TeeVeeMan2@gmail.com
Aug 30, 2011 | Element Televison & Video
I need a tv base for a 19" FLX-1911B HD-LCD TELEVISION. THANKS!
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Aug 26, 2011 | Element Electronics FLX1911B 19 in. LCD TV
Looking for a base for a element tv 1000186380006764 model s/n also a remote
The tv base stand tries websites like Amazon.com,Ebay.com to buy a used or new base stand.The tv remote cotrol,try website like Remotes.com to buy an exact remote or very close to the original remote.
Feb 02, 2011 | Element Electronics FLX-2210 22 in. LCD...
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
Mar 30, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Lost the screws for the stand, need the specific screw
Just called the Element Parts Department because I had the same problem.
M5 x 18 mm
Enjoy your properly secured TV!
Mar 15, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element Electronics FLX2211B 22 in. LCD TV Logo
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
