Question about HP Pavilion dv6226us Notebook
How to reload O/S from the D: partition? - HP Pavilion dv6226us Notebook
  • 487 Answers
Hi, not sure what you meen here i.e completely reinstall or repair? But here is to reinstall, let me know if you wish to repair! Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Posted on Jul 10, 2010
Need to reload xp on my twinhead r15d from the hidden partition on HD
you need to access the boot menu, usually F10 when it boots up, and then select the relevant option, IE; boot from recovery partition?
Jan 13, 2013 | Twinhead DURABOOK - D15RP (D15RP20TLGSMNI)...
Partion of c and d for a 100 gb dell inspiron recomended portion
Why not just use the totals disk as one big partition? It's much easier and most times people fill up the c partition while the d partition sits there empty.
It would serve you better to have one big contiguous partition.
Jun 04, 2012 | Dell Inspiron 6400 (883585945283) PC...
HP recovery partition wiped, and unrecoverable, ..............need an image reload it, once reloaded not sure if it is recognized by bios.
If you didn't make a set of recovery dvd's or cd's when you first bought your machine, then you can purchase a set by going to the HP site with your serial number, model, etc.
Apr 04, 2017 | HP Pavilion DV9910US Notebook
Presario laptop runs extremely slow. Have run
IF it is HP PC than you can simply go ahead a reload the factory settings in the OS from the Recovery partition without the help of the CDs. Every HP pc have a separate partition where the image of the entire OS is loaded. you can simply go ahead and reload it from that partition. Just follow the following steps-
1. Turn off of the pc completely.
2. Disconnect all the external devices and the internet connection.
3. As soon as you turn on the pc start tabbing the F11 key( for Windows Vista).
4. It will take you to the recovery manager and from there you can just follow the onscreen instructions.
Jul 10, 2010 | HP Compaq Presario C500t Notebook
Recovery
its often a hidden partition which you can reload the software from
If you goto start> control panel > administrator tools> computer management> disk management > you should see the partition there
Apr 01, 2010 | Acer Aspire One PC Notebook
Laptop wont boot...it wont load past the very first boot screen where it asks you to hit f12 for boot menu and f2 for system utilities it have the windows vista OS...is there a problem with the hard drive?...
Windows is corrupt...reload Win OS....if possible re-install Windows in a different partition say D: or E: etc (if u have more than 1 partition) and then once done let it boot from that and let Win load....take a full backup of all of your critical data to a USB pen drive....then reload Win CD in the Cd drive, switch off and switch on PC let it boot from CD and delete all partition on HD, format the disk fully and repartition the disk and load Win in C:
pls leave a feedback
Mar 03, 2010 | Toshiba Satellite A135-S4467 Notebook
I have a Systemax ascent syx-ms-7309. Is there a reload partition like HP and Dell? Or is reloading the OS from a CD the only way?
I would just reload from a cd...Darren
If you have a reload partition you could hit F8 while it eas booting and see if they have an option..Hope this helps..Darren
Sep 30, 2009 | Systemax Ascent PC Desktop
I cant format my usb
Try this, It might work:
i)Try to put Pen Drive or USB in usb port and insert an Windows XP CD and try restarting start and i think u the know procedure of formating Window XP or reload OS(let me say that i'm not formating or reloading OS on ur system, there is small procedure over there after that u can use system normally....)
ii) when u reach a blue screen that show all the partitions of ur system (like C: D: E:  ....), observe it will also show ur usb partition(mention memory....) separately,,, try to use this  option :
 Delete Partition by pressing D(usb partition being highlighted...) and then follow instruction .....and now  u will see that there is no partition letter(such as D, E , F) assinged to ur usb
 Now Create an partition on that by pressing C ... this will create an partition and it will retain or give  name or lettering to it(such as D, E, F)
 after this donot continue format the system, just exit from by pressing ESC button .... and ur system will start normally, ...observer usb now u will be able format.... from now..
Thanking you,
M. Sridhar.
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Fomatting not possible it says write protection
i) Try to put Pen Drive or USB in usb port and insert an Windows XP CD and try restarting start and i    think u the know procedure of formating Window XP or reload OS(let me say that i'm not formating      or reloading OS on ur system, there is small procedure over there after that u can use system            normally....)
Thanking you,
M. Sridhar.
Dell latitude 600
You mean a recovery partition on your HD? No. Reload your OS.
Dec 18, 2008 | Dell Latitude D600 Notebook
HP Pavilion dv6226us Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
