Question about Whirlpool ET8CHEXSQ Dryer
Strong burning odor from dryer. It went away then is back today.
  • 10,865 Answers
Hi. pull your dryer out from the wall and remove the vent pipe. Check inside the lower rear of the dryer for lint in the beginning of the exit pipe and then throughout the entire pipe. This can cause a fire so clean this before you use it again. J.
Posted on Jul 10, 2010
Why suddenly a strong odor of burning fuel when heater is operating?
Improper air to fuel mixture, way to rich.
Does this heater have the ability to adjust ratio?
if so, play with adjustment until odor goes away.
Mar 25, 2015 | DynaGloDelux Dyna Glo Delux Liquid Propane...
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
How do I remove odors from this dryer?
Probably build up of dust and lint inside cabinet. You need to unplug dryer, remove back panel and vacuum out lint. If excessive lint found, would indicate insufficient cleaning of lint filter or restricted outflow vent or hose. If odour is electrical smell or burning plastic check all electrical connections and insulators for signs of browning or overheating. Strong pungent smell could be motor winding overloading or burning out. Will need electrician.
Apr 02, 2011 | Dryers
Odor
If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  1. First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  2. Move all containers of flammable liquids at least 50 feet away from the dryer.
  3. Then, try to clear the odor, by running a couple of loads of old rags or towels.
Apr 22, 2010 | Whirlpool LER4634J Electric Dryer
Strong odor coming from dryer
Usually when there is a strong heat (burn) smell from the heat element, it is telling you that there is poor air flow. This has nothing to do with the model. It is a blocked or restricted vent line, or an internal blower wheel malfunction or a lint blockage further in the machine that is restricting the air flow. WHEN AIR MOVES CORRECTLY, THE ELEMENT HEATS NORMALLY AND DOES NOT GIVE ANY OVERHEAT ODER.
Oct 11, 2009 | Kenmore 63942 Dryer
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Burning smell during drying cycle, coming from the inside back left grate. The grate appears discolored.
Usually when a gas dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat . If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Jul 11, 2009 | Whirlpool WGD6200S Gas Dryer
Headlights stay on after truck and lights are turned off.
check the wire connections to the switch also the switch itself may have burnt out
May 30, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Whirlpool ET8CHEXSQ Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
