Question about Samsung Digimax A7 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
  • 10,865 Answers
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Posted on Jul 10, 2010
    Problem Solver:
  • 5 Answers
I found using Lithium batteries helped too, as they seem to have more juice and last longer.
Posted on Sep 29, 2010
Digital camera gives low battery noise and turns off the batteries are brand new and it wont even turn on help please ?
Posted on Sep 12, 2010
My Vivicam is always showing low battery, even I replaced the batteries as per specification.
i am not sure if you are using recharchable batteries but if you are that is the problem those go out really fast in these types of cameras try using fresh batteries.
Dec 22, 2012 | Vivitar ViviCam 7024 Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Batteries
I had the same problem......I went to the store that i bought the camera from and i bought a kit that contained four rechargable batteries, a battery charger, & it also came with a car cord that goes into your cigarette lighter so you can charge a set in your car. PROBLEM SOLVED for $26.00 + tax.
I take a whole lot of pictures (freelance photographer) and I ALWAYS have one fresh set. As soon as the set in my camera goes low i throw them on the charger and put a fresh set in my camera. By the time the fresh set goes low, the set in the charger is ready.
Sep 07, 2008 | Samsung S630 Digital Camera
Olympus Camedia C-2020 Zoom - always reads low battery and then "dies"
Safe way - Try using brand new and fully charged NiMh.
Not for novice - Battery contact points may need cleaning. Use contact cleaner with a cotton swab.
Do not try - Spraying contact cleaner or WD-40 in battery compartment.
Last option - Service center.
Mar 08, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Camera wont turn on
The camera may in fact be hung in voice recording mode, or may in fact have a low voltage error or internal failure. Suggest that you follow this routine. 1 remove batteries and press the on button, nothing should happen. Allow camera to sit for five minutes. 2 remove memory card if one is installed into camera. 3 install two fresh batteries in camera and attempt to power it on. 4. once on set the time and date. attempt to take a photo. then cycle the camera off. Once again power it on and see if the settings remain intact. If it is working then power off and insert the memory card and test again. I have found that allowing the camera batteries to run low and die in the camera cause a series of problems like the one that you have. Always use rechargable batteries of the Nickel metal hydride construction in this camera. This is the only known reliable power source for this camera. Note: camera instructions for this model can not be found on the samsungusa site and you will have to go to http://www.samsungcamera.com to find instructions for this older model.
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
Battery level low
welll the problem is is that you have to buy special batteries like alkaline normal bateries will not last and will always come up with that error message
Aug 31, 2007 | HP Photosmart 735 Digital Camera
Nikon coolpix L4 won't take pictures & turns off
I have the same camera & personally, I hate it. My camera does that all the time, sometimes, it takes a while for the picture to actually take. Try holding down the button for a while, that's what I have to do with mine. The camera sucks up all the battery energy with only a few picture takes which I really don't understand. I think that's also why it's cutting off while you're using it. Does the phrase, "Warning: Batteries exhausted" sound familar, especially right before the camera shuts off? Oh, & before I go, my personal advice to you is: Get a new camera. I don't even know why I bought mine, soon I'm getting a new one. Yay. I hope this helped you, sorry about the camera problems. Much luck! :D
Jun 09, 2007 | Nikon COOLPIX L4 Digital Camera
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Sep 08, 2005 | Pentax *ist D Digital Camera
Samsung Digimax A7 Digital Camera Logo
840 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
