Question about Behringer Pmp3000 16 Channel Audio Mixer
Sound cutting out
I am using a drum machine through the mixer, no problems, then I run a mp3 player and I get a popping noise and everything cuts out. I leave it for a while and it works again but not for long. Seems like an overload problem but but I can't think how it's being overloaded
  • Behringer Master
  • 5,603 Answers
You may be having early stages of arc over in the main amp. This leads to catastrophic failure of the power amp section (usually the rearward one) and sometimes the power supply.
Facing the back of theunit, usually the left speakon connector is the one that connects to the section that fails.
The arcing is between two layers of a multi-layer board.
Note, if you smell smoke or pop a fuse DO NOT continue to use the device but get immediate servicing.
Posted on Jul 12, 2010
Noise from a Yamaha EMX 2000 Powered mixer
Sounds like it might not be cleaned enough. They may have done the pots but the internal circuit boards may not have been done enough.
May 11, 2016 | Yamaha Music
I have the same mixer (behinger europower, 12 channel). The other day it was being used for a regular speech when suddenly all lights on the mixer started flickering and the sound got cut. After about 30...
You do not specify what model you have.
It could be related to the power supply shutting down (e.g. from overheating) then restarting after cooling down.
If the mixer has a fan, you could check if it is uncovered, clean and running.
May 11, 2014 | Music
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
The sound on my synths is not working. I just bought reason5, and all that makes noise is the kong drum machine. I am very new at this so it is probably a stupid problem, but whenever I pull up the...
okaye, i justt figured itt outt, hopefully you gett an email aboutt this postt...
so anywayz yo,
how many instruments you have hooked up to your mixer? thats the key, #1.
make sure you have atleast ATLEAST 2 mixers in your start up program, once you use the max output input for your original mixer, the next instrument patch you load will not be routed, (no more space), you'll have to route it manually (press Tab) *get familar with routing your own devices, for reverb/chorus and such,
this applies to everything about recieving sound from your project/keyboard. and just route your extra devices on the new mixer --they go up to 14 channels, i have like 22!
so thats my solution, hope itt applies.
Dre'
South Caro-line-em- up
~1~
Jan 16, 2011 | Propellerhead Reason 5
HOW DO YOU TURN DOWN THE HISSING NOISE
You can cut the treble gain some BUT most importantly is to send adequate signal to this speaker so volume level does not have to be set high when sending LINE LEVEL signals to it. Hissing noise is a product of the statistical noise that occurs in electronics. Running any device at high gain invariably brings up the hiss level. Managing thee signal levels is the responsibility of the sound engineer.
ALSO feed ALL interconnected equipment from the same receptacle or power source, even if it means running a power cable to a mixer alongside the snake. ALWAYS USE BALANCED audio cables whenever possible.
Dec 24, 2010 | Samson Auro D415 - 2-Way Active Speaker...
Right side audio cutting out on a Mackie 32-8 mixer board
Try cleaning al of the sliders using an electronics cleaning spray. Choose one that contains a lubricant as well. Dirty sliders can cause this especially at low volume levels. If that does not cure the problem, there may be a defective IC inside the unit. Many mixers use opamp ICs as buffers and final stage amplifiers. These are inexpensive and can fail in that manner. Without knowing the specific make and model ogf your unit, I can't give you any details. Please post the make and model and I'll try to provide additional possibilities.
Dan
Apr 08, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Peavey escort
I would try unplugging some of the extras. All of that could have been causing your line voltage to sag too low for the mixer supply to operate properly.
Jan 17, 2009 | Peavey 00511800 Escort Portable Sound...
Behringer Pmp3000 16 Channel Audio Mixer Logo
164 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
