Question about Epson TM-L90
I have a Epson tm-l90 label printer, and after printing a label it feeds four blank labels then does a cut. how can I stop it feeding these blank labels. john
2 Suggested Answers
Niraj Limbu
  • 183 Answers
SOURCE: Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Posted on Feb 24, 2009
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Paper feed to far for labels
You should adjust the shutter as well to the size of the paper. Another thing is you can manually select the paper type under the printer settings. Go to Printers and Faxes > Properties of your default printer and manually select the paper type.
Sep 30, 2008 | Epson TM-L60II Thermal Printer
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
Paper not feeding
Hi
Open it up and check the installation of the labels.Make sure the roll is correctly fitted.
Turn it off and on.Solved?
Turn the printer off .
Press and hold the power button and then turn printer on.
Release the button.
The printer will print a test page.
Try feeding now.
Mar 01, 2012 | Epson TM U200B Matrix Label Printer
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Make sure,
Good luck
Feb 24, 2009 | Epson TM-L90
Feeding
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Jun 26, 2007 | Argox R-400 Thermal Printer
Epson TM-L90 Logo
265 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
