Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
WTW6400 Every time it goes to the spin cycle it is unbalanced and shuts down.Ive checked for level and proper loading.Any ideas?
Mine does the same thing every time. It knocks and bangs and scares the dog as well as guests. Sometimes it fixes itself and sometimes not. Seems to me that there is something in the suspension that has weakened over time. Have not seen anything written about that though. Possibly the liquid in the balance ring is obstructed from moving around properly to act as a counter balance. Our floor is concrete and the machine is level. As we could operate the machine competently for a couple of years, it's doubtful that the problem is operator error!
For a couple of years it worked fine. Well, it functioned but my wife has complained from the beginning that it does not get clothes as clean as our old inefficient machine which we gave away in working order but would like to now have back. One corner of the porcelain turned yellow from the bleach fumes. The frame under the cover is rusty. When the machine goes into UL mode, it leaks.
Initially we had a problem with it ruining clothing in every load following a load of whites with bleach. It saves a few drops of bleach to deposit on our colored king bed sheets and some nice shirts. A new valve replaced under warranty remedied the problem, although it is not clear why it did so. The Whirlpool factory tech reversed the hot and cold water supply hoses. We had a couple of cold showers until I figured out what he had done.
Our whirlpool microwave quit after 5 years. We were told it needed 2 new circuit boards which cost more than the unit did when we purchased it.
I have always tried to buy American, as hard as it is. Our next appliances are going to be from Japan or Germany and not Whirlpool.
Posted on Jul 11, 2010
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Ds codemkeeps coming up even though the door is shut
The "dc" error code indicates an unbalanced load is preventing your washer from spinning properly. Try redistributing the load, then press the Start/Pause button. If the load appears well-distributed, you may need to make adjustments to the leveling legs to make sure the washer is properly leveled, removing the clothes and running a spin only cycle to make the necessary adjustments. Once firmly leveled, be sure the plastic leg locks are tightened to prevent them from vibrating loose.
Apr 14, 2014 | Samsung WF337AA Front Load Washer
Spin cycle tub becomes unbalance
When the drum gets unbalanced more often then not, there's a few things to check:
1. Check to make sure your machine is level. Check level from side to side and also front to back. The machine has leveling feet to adjust. Make sure they are all in firm contact with the floor when leveled.
2. Wash items that are alike in material. In other words, wash towels with towels, shirts with shirts, etc. If you wash a load of shirts with a towel, it will have a tendency to get unbalanced quickly.
3. Avoid over-stuffing the machine and washing under sized loads. Both of these scenarios will cause a tendency to go out of balance on the spin.
This will solve 75-80% of unbalance issues. Let me know how it goes..
Dec 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Unbalanced spin cycle
it sounds like one of the levellers is out or the bearings in the tub are shot.
Jan 21, 2009 | Kenmore Washing Machines
Front loading washer bangs and thumps during spin cycle
hi may i suggest you remove the top cover of machine and check the drum mountings(rubber) and the spring/s that are connected to the bracket on drum have not broken /come off just one other thing ? when machine was installed was the bracket under the top cover removed b4 connecting and using machine ? this bracket is for security/stability of drum whilst being transported see instruction book ? it is not the first time iv'e encountered this bracket not being removed by customer diy installation worth checking? best wishes
Oct 23, 2008 | Washing Machines
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
Nov 25, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
967 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
