Question about Goldstar DH504EL Dehumidifier
Is there a manual for the Goldstar DH504#LY5 on line anywhere? I'm having the same problem as others where it ices up and no water in the bottom tub. It just freezes up. Anyone find the fix that works? I would stay the heck away from Goldstar Dehumidifiers
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: I have a Goldstar DH504
Hi rwheat3,
If you're experiencing slow production of water, it is often caused by the coil. If the compressor and the fan are running but the coil is totally blocked then you will get no water production. The easiest way to resolve this issue is by checking the coil. Air needs to be continually moved over the cold coil to get the water out of the air.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 22, 2011
Immediate ice build up on coils no water in tank?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jul 10, 2011 | Goldstar Dehumidifiers
GOLDSTAR DEHUMIDIFIER SUDDENLY NOT LEAVING ME MUCH WATER IN CATCH...FREEZING UP IN BACK?
heatman101
May 19, 2011 | LG DH30 GoldStar Dehumidifier
I don't have the manual and need to replace and/or clean the air filter on my Goldstar DH304. Where do I find it on the appliance?
if this is the correct picture - pull out the collection bucket and reach just inside the opening at the top (just at the bottom of the grill in the front) the filter is plastic and pulls straight down. Clean it tin soapy water, dry it, and slide it back it place.
Oct 10, 2010 | Goldstar DH304 Dehumidifier
My Goldstar dehumidifier is still draining water, but is forming snow/ice out the top of it. I've had a couple of years and has worked beautifully. Any suggestions?
Your unit has a sealed system leak. The sealed system is warrantied for five years. Find your receipt and call an authorized LG dealer to initiate an exchange.
Sep 30, 2009 | Goldstar DH504EL Dehumidifier
Solenoid is not opening for water to ice maker
The only thing that controls the water valve on the IM side is the IM itself. If you can power up the water valve manually and it works fine then you need to take a look at the IM
Jun 10, 2009 | Goldstar DH504EL Dehumidifier
Ice build up
I would say you need a humid control on your unit.it may be running more then normal.
May 08, 2009 | Goldstar DH504EL Dehumidifier
Fan fixed but evaporator solenoid keeps activating at times
the purpose of the valve is to de-ice the evaporator and the valve is turned on by a timer usually. in normal operation, the evaporator builds up with ice (that is how water is extracted). when the valve operates, to put it simply, the hot gas is routed to the evaporator and hence melts the ice off
Aug 28, 2008 | Goldstar DH504EL Dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Leaks water
The water may be condensation dripping in an area where the catch components are not able to catch it. The largest line that exits the cold coil and ends at the compressor should be insulated without any tubing showing all the way back to the compressor, deficits in the insulation (even small ones) could cause condensation to form and drip.
Mar 09, 2017 | Goldstar DH5010B Dehumidifier
Goldstar DH504EL Dehumidifier Logo
53 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
